NEED HELP with the headlight replacement
Old Jan 20, 2010 | 02:07 PM
toroz06's Avatar
toroz06
Default NEED HELP with the headlight replacement
How do I replace the headlights assy? on a z06 c6 2007
the dealer wants to charge me 500 just to replace them
Any one have pics. from 1 to 10 how complicated it is? can it be done in a weekend?
Old Jan 20, 2010 | 04:05 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Use the search function, Many Many threads on replacing the headlights... And front bumper cover.
__________________
GO GATORS!!!
2008 Vert
Owned since new in 2007
www.c6c7vette.com
Old Jan 21, 2010 | 08:30 PM
LR'z-Z06's Avatar
LR'z-Z06
It's been a while. I took off the cover(painted piece). I took off the plastic wrap around piece. I removed the glass and metal headlight piece. Turn the sockets counter clockwise to remove. Take your time and it really is not that hard.
LR
Old Jan 21, 2010 | 08:38 PM
c6 batmobile's Avatar
c6 batmobile
Open the fender wells and loosen take the bolts out of the top of your fenders too. Then you should be able to reach inside disconnect the light and then lift the fender up to pull it out. Its pretty simple. I suck at writing step for step instructions but its really simple.
Old Jan 22, 2010 | 10:14 AM
toroz06's Avatar
toroz06
Ok, so the front bumper I don't have to take it out? also I'm afraid of take the bolts out of the top the fenders and mess the alignment, how did you align your after you were done?
Old Jan 23, 2010 | 09:41 AM
c6 batmobile
No you do not have to remove the front bumber if you do not want to. It is almost impossible to mess that alignment up. I pulled it up when I put the headlight back in and dropped the fender back down they were right on track then I just put the screws back in.
Old Jan 24, 2010 | 05:00 PM
toroz06's Avatar
toroz06
I just finished replacing the headlights one side was a nightmare because I was trying to figure out how to do it. ones I finish that side the other one I did it in 15 minutes
To NEED HELP with the headlight replacement
