Ls3 heads
Old Jan 21, 2010 | 10:02 PM
juiced c6's Avatar
juiced c6
Default Ls3 heads
Is it better if you have your stock heads worked or go aftermarket such as afr? list of mods Fast 102,ported polished tb,lg g6x4 cam,vara ram,kooks 1 7/8 long tubes no cats, magnaflow exhaust,crank pulley,nos plate system 100 shot. Thanks
Old Jan 21, 2010 | 10:16 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
AFR does not offer an LS3 head.
We can CNC yours,new LS3 GM castings or our own LS3 castings - ~370 +cfm intake / 260 + cfm exhaust - any combustion chamber size from 60-75 cc - we fully do the complete head in our own facility -and that includes flow design & flow testing , CNC machining & all finish work.
Old Jan 21, 2010 | 10:22 PM
juiced c6's Avatar
juiced c6
I was just using afr as an example. What type of cost and hp numbers?
Old Jan 21, 2010 | 10:31 PM
0C_Williams@RPM
Former Vendor
Using your heads the complete cost = $1,485.
CNC - complete
Serdi, Multi-Angle Valve Job
Milled & cc'd
Stainless Steel Valves
Springs, ti retainers, locks,spring bases, seals
HP depends on the supporting cast of mods but we have seen 490 - 530 RWHP.
To Ls3 heads
