New Pressure Sensor(s) Needed????
If it's the senor, I am inclined to replace all four sensors to have the best situation of not having a second or third sensor die and I have to go through this all over again.
Can my dealer verify whether it's just the sensor or something else?
If you lived nearby I would check them for you, but your just a little too far out of the way for me
Have you disconnected the battery, or has it run down?
Did you drive the car, or were you just starting it up while it's in winter storage?
If the battery is disconnected or runs down the TPMS will lose the last known pressures. In that case you must drive the car faster than about 20 mph for a few minutes to wake up the sensors and get them transmitting in the drive mode (transmitting once per minute). That should get the DIC displaying the proper pressures again.
If that doesn't work, you've either got a bad sensor, or maybe they just need to be programmed again.
Bob
Bob
No, the battery is fine and it hasn't been disconnected.
I don't really store the car for the winter; just keep it in the garage ready to go for when we get a clear 50+ degree day. I had driven it last week and did not get the message and it had sat for two weeks without being started prior to that.
We drove 300+ miles with several shutoffs and restarts before getting home.
, the "Service Tire Monitor" message did not appear and the RR tire sensor was reading the correct pressure.I stopped somewhere for an hour and when I restarted the car to drive home everything was normal and all of the sensors were operating correctly.
I appreciate all of the comments, recommendations and replies and will keep this in my list of subscribed threads for future reference.
Thanks again to all...Happy motoring....
Bill
