Maintenance Intervals
Old Jan 27, 2010 | 01:50 PM
Richor's Avatar
Richor
CF Lifetime Member
Default Maintenance Intervals
I searched but found nothing.
I am approaching 32k miles on the vette. I was wondering how often the clutch fluid, tranny fluid. diff fluid etc etc should be changed with pretty spirited daily driving. I push the car hard almost all the time and I want to make sure she is taken care of.
Besides oil changes what should I make sure to do every 3-4-7-8k miles?
Thanks much !
Old Jan 27, 2010 | 07:03 PM
Topas's Avatar
Topas
It's stated in your owners manual, which can be found for example here or here. For 2008, it's on the page 384.
Old Jan 27, 2010 | 07:21 PM
Richor's Avatar
Richor
CF Lifetime Member
thank you sir
Old Jan 27, 2010 | 07:33 PM
Richor's Avatar
Richor
CF Lifetime Member
Ok I just reviewed the owners manual. regarding changing clutch fluid, manual tranny, diff, etc it says its not necessary to replace unless a leak is noticed. Then to check the scheduled maintenance section. I did check the scheduled maintenance section and it still mentioned nothing about the intervals for clucth, manual tranny, diff etc
Old Jan 28, 2010 | 12:40 PM
CMY SIX's Avatar
CMY SIX
you must be kidding! they have a lube section in the owners manual?
Old Jan 28, 2010 | 05:26 PM
Bandit1's Avatar
Bandit1
I change my oil every 5k miles. I change the tranny fluid, diff gear lube, brake and power steering fluids, and flush the radiator every 30k miles.
To Maintenance Intervals
