Service Active Handling System???
Old Jan 29, 2010 | 10:26 PM
luckycharmer03's Avatar
luckycharmer03
Default Service Active Handling System???
I was driving today when my car started to beep and flashed "service active handling system" My car is an 05 Z51 with 25000 mi . Does the light come on for a normal maintenance visit or does it come on cause something is wrong with my active handling? Thanks in advance!
Old Jan 29, 2010 | 10:32 PM
bob guzzy's Avatar
bob guzzy
It could be just a glitch if it came on and went off after re set, if it stays on have it checked out, could be just the cold affecting the gas in the shocks.
Old Jan 29, 2010 | 10:34 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Something's wrong, don't ignore it. Do a Search, there's lots of info on this.
Take it to the dealer, there is a TSB issued for this problem. The usual fix is a connector near the steering column but there can be other causes.
Worst case scenario, the AH will intervene and steer you into the ditch. Just turn AH off and get it fixed. Not covered on your warranty but usually not too expensive.
Pretty common problem, you are not alone.
Old Jan 29, 2010 | 10:44 PM
KarlK's Avatar
KarlK
From: Beats UD regularly playing 3D chess, and at life
electrical gremlin
telescopic wheel? - clip fix - TSB
Otherwise, aftermarket electrical acccesories (stereo, switches, etc.) can cause the Active Handling to display on the DIC.
BCM
Old Jan 30, 2010 | 10:33 AM
luckycharmer03
Thanks!!!
Old Jan 30, 2010 | 10:36 AM
luckycharmer03
by the way what does TSB stand for? thanks
Old Jan 30, 2010 | 01:24 PM
SunsetStroker's Avatar
SunsetStroker
Technical Service Bulletin (spell check)
Old Jan 30, 2010 | 02:14 PM
Hogvette's Avatar
Hogvette
I had same issue... Service Active Handling msg 3 times... took it to the Dealer and they installed the TSB remedy at zero cost. No problem since.
Old Jan 30, 2010 | 02:57 PM
SunsetStroker
Youre still in warranty though right?
Old Jan 30, 2010 | 03:48 PM
Hogvette's Avatar
Hogvette
Yes, I was still under original warranty. The fix took less than 1.5 hours.
Old Jan 30, 2010 | 08:58 PM
luckycharmer03
ahh thanks!
To Service Active Handling System???
