No harness bar camera mount
In looking at the car it seems like it wouldn't be tough to add a mount between the seats right on the edge of the bulkhead. Is it safe to screw into the carpet there? The GoPro is very light so it doesn't have to hold much weight.
During my misspent youth (when I was '40-ish!'), I did considerable 'club racing' in the Porsche Club of America with my Porsche 911. The first season, I raced the 911 (in class) virtually stock... OEM lap belt and all. Then, in the off season, I did a boat load of 'mods' including a full race harness.
Well, as it turned out, the benefits of the harness were just what I needed... no longer did I expend an ounce of energy trying to 'hang on' to the car... nope, I was firmly in the seat.
Before actually experiencing the difference, I would have never believed just how much improvement the harness would be.
Go ahead... give it a try (and it will give you a place to put your camera).
R
b
The type of racing I do isn't wheel-to-wheel, it's either straight autocrossing or maybe once or twice a year a casual HPDE.
Just be ready for when those autocross events turn from 'casual' to really wicked-competitive, you will be wanting a harness!
The TeamTech harness that I have in my C6 has never had any track use (yet), I just 'sit on it' as I drive the car around town and use the factory lap belt so keep me safe and legal. And, dang, it looks teriffic!
Below is an excerpt from the Nat'l Corvette Museum site:
http://www.corvettemuseum.com/regist.../virinfo.shtml
This is from the "VIR Participant's Package" and concerns requirements for the VIR event coming up June 28-29, 2010:
13) Harnesses – Restraints must be the same for driver and passenger. The stock 3-point seatbelt is perfectly fine for this event. If a person chooses to put in a “race harness” they must do so for both seats. A driver cannot use a harness unless there is an equal one for the passenger. Race Harnesses must pass through the seat and not around it and be installed as per manufacturers guidelines. Installation accuracy is the responsibility of the student.
You'll notice that there is a requirement that if you're going to carry a passenger/observer/instructor in the right seat, the right seat must meet the "equal restraint" rule.
Also, if you have a harness system, the shoulder straps must pass through the seats. I believe some groups are so concerned and lawyered-up over liability that a seat with harness pass-through holes has to be manufactured that way as a race seat, but it doesn't say that in the NCM info. There are some large plastic grommets that are sold that can be installed in OE seats to pass the straps through.
Some race suppliers used to sell sternum straps to hold shoulder straps together it they passed around the headrest on an OE seat, but I don't believe anybody sells them any more because they are considered unsafe.
Here's a picture of forum member Wayne O's very nice setup, and he doesn't have any problems with the groups he runs with out in the Tucson/Phoenix area:
Not all groups require the harness to pass through the seat (I'm pretty sure PCA and Bimmer groups that put on events have that requirement), but many do and more may adopt it as time goes by and liability concerns grow.
Here's a picture from the Simpson site:
You can see that it may be problematic to get the shoulder harness to come across the shoulders from the correct angle, depending on your bar and pass-through holes.
I believe that a lot of states will not accept harnesses for street driving, so you may have to make sure your OE 3-point belt is still installed and functional for street driving. With many race seats the OE belt system doesn't come across the lap properly because of the higher side bolsters and the OE belts may not work properly at all with many race seats.
Good luck, but putting a harness system in a DD can be a difficult issue to deal with.
Bob
I'm just wondering if it's safe to screw into the bulkhead between the seats to put a small camera mount there. It would allow me to put off having to buy a harness bar until I actually need one.
As far as screwing into the bulkhead to mount your camera, be careful putting any holes into that area. I've never been into that area, but there are fuel lines in there you don't want to puncture. There may be enough room for some short mounting screws to go into the area without hitting anything, but there are 2 fuel tanks and that area has crossover lines and fuel return lines running through that hump in the very front area of the cargo compartment.
Bob
pics
i can remove/ install it in 2 minutes
videos showing integrity:
bg road tour
aimed at gauges
more driving
not sure if you know or not, pull the safety belt all the way out and it ratchets back to hold you pretty tightly, use the seat motor to make it extra firm
good idea Corvette Brey-Krause Harness Mount Bar : C6
http://www.westcoastcorvette.com/p-1...nt-bar-c6.aspx
Just in case
Bob
Sinister's tripod setup is pretty slick, but the gopro camera doesn't have a normal tripod mount. I'm not sure if it could be adapted to fit.
I LOVE the Brey-Krause bar. It's a beautiful piece, but it's pretty expensive, especially as it would only be used as a camera mount.
Maybe I'll just troll the parts for sale forum and try to pick up a used sharkbar or something.
As to your original question though, there was a guy at VIR last summer who basically used a piece of bar stock bolted to the riser behind the seats and attached a camera to it.
A long time ago there were a couple forum posts about guys who mounted camera tripods in their rear cargo area. I recall the one guy secured the tripod with metal guy wires. He said the tripod and camera were secure and it worked well.
Just a couple ideas...good luck!
If you have the harness installed why not use it? IMO using a harness (even driving around town) isn't all that inconvenient. You wouldn't even have to use the sub-strap (if any) for in-town driving.
