We have several of them inbound now. They are the 599 kits, we will be making some changes to them. I will post them up when we are done and what mods are being done to them.
Justin
and these will be modified with Edelbrocks blessings? i.e. warranty
Why would this be better than the kits already out, I would think that they would be better, and cheaper at this point..... Well time will tell I guess!
I currently have a UD Pulley pinned. That would take much of the work out of installing a Eldebrock or Maggie type Supercharger after reading the installation instructions. Will that effect the performance ?. If they come out with the ZR-1 type it would enhance the LS2's look as well as all the
Hp/TQ increase
Correct me if i am wrong, but if you have a UDP, then won't you need an even smaller compressor pulley to reach the same PSI? Guess that's not really a big deal, but you can't just use the standard kit.
I think that the key for a lot of folks looking at it would be the warranty that comes along with it. What exactly that means, and how useful it ends up being remains to be seen, but that right there is a decent part of what you're paying for.
I'm considering this SC on a 2005. I understand that I can put the L92 heads on my LS2 block and then the LS3 will bolt on; but I don't know what this will involve. Does anyone have experience doing this and would like to share their know-how?
Dont bother with the L92's on the LS2. The only hold up on the SC for the LS2 is the ECM programming. The program supplied by Edelbrock to flash the ECM on an LS2, won't be set up for an LS2 with L92 heads.
yea, your car will blow up wait for the proper kit.
Let me clarify my question. When the kit for the LS2 comes out, will there be a problem if the LS2 that it goes on, has after market LS2 heads, such as Trickflow?
you really need to call Edelbrock Tech instead of relying on people with no clue of if it will really fit or not. just b/c a stock manifold will bolt to Trickflow heads doesn't mean the Edelbrock will fit properly or the accessory brackets will work. good luck.
Not sure, they don't have any additional vids online.
This is the description:
Edelbrock E-Force Supercharger installed by Kustom Creations (Sterling Heights, MI) on a C6 LS3. Mustang Dyno Run. 506 RWHP @ 6500 RPM. 434 FT-LBS Torque @ 5200RPM.
Wow! That's more HP (595) then stated by Edelbrock (554), but then again, I'm not a big believer in Mustang dyno data. Maybe that was the Competition Kit?
