Listen to the SPINMONSTER
Old Feb 4, 2010 | 06:12 PM
cranky's Avatar
cranky
Default Listen to the SPINMONSTER
just got off the dyno, tuning my ls2 with spinmonster ported intake, throttle body, and cam recomendation. all i can say is WOW!!!!!! car has an A4 transmission and stock converter. 3.15 rear gears. made 438 RWHP and 419 TORQUE. driveability is perfect, with no problems. very satisfied customer of spinmonster.
Old Feb 4, 2010 | 06:27 PM
dennis50nj's Avatar
dennis50nj
he knows what hes doing
Old Feb 4, 2010 | 06:40 PM
Richor's Avatar
Richor
CF Lifetime Member
can you pm me how much you paid for all that? I mean the spinmonster intake, TB and cam?
Old Feb 4, 2010 | 07:17 PM
gnfan's Avatar
gnfan
What cam was that? 232/234?
Old Feb 4, 2010 | 07:23 PM
c6 batmobile's Avatar
c6 batmobile
What cam? Who tuned it? Mustang or dyno jet dyno?
Old Feb 4, 2010 | 07:35 PM
JayplaySS2's Avatar
JayplaySS2
Spin is the man, I'm waiting on his big LS3 cam
Old Feb 4, 2010 | 07:56 PM
cranky's Avatar
cranky
tuned on a mustang dyno. cam is spin's design. 224/224 XFI/XFI 155+2
Old Feb 4, 2010 | 08:17 PM
Richor's Avatar
Richor
CF Lifetime Member
Cranky, thank you very much for taking the time with that detailed PM. I will be sure to hit up spin soon.
Old Feb 4, 2010 | 08:39 PM
cranky's Avatar
cranky
no problem, glad to help. all spin's proceeds go to st. judes. a very good cause indeed !!!
Old Feb 4, 2010 | 08:42 PM
jxhunte's Avatar
jxhunte
Cranky, is your ported intake a FAST intake (SpinFAST). I assume when giving your CAM specs, your LSA is 115+2 and not 155+2 as stated in post #7.
Old Feb 4, 2010 | 08:54 PM
SpinMonster's Avatar
SpinMonster
Old Feb 4, 2010 | 09:28 PM
cranky's Avatar
cranky
yes, 115+2, the intake is a stock spinmonster ported one.
Old Feb 4, 2010 | 10:09 PM
SpinMonster
I'm porting stockers for exactly 4 more days then I'm shutting down the porting to move on to graduate study at a local university. Tech support is still free and I will give any needed support to customers who bought from me.
Old Feb 4, 2010 | 10:11 PM
SpinMonster
Its already out. PM if you need one.
Old Feb 4, 2010 | 10:48 PM
knkali's Avatar
knkali
a scholar and a gentleman
Old Feb 5, 2010 | 01:26 AM
SpinMonster
I have 2 new ported LS2 intakes for sale outright for $400 if anyone is interested. PM for details on payment/shipping.
Old Feb 5, 2010 | 02:47 AM
SpinMonster
Sorry I took so long to post the dyno sheet.
The car was dyno'ed on a mustang dyno and with 3.15 gears. Compression is stock at 10.9:1 while optimum would be about 11.4:1 (use .045 cometic gaskets for this) on 93 at sea level which would bump power 7hp/10rwtq and about 25 more rwtq at 3000rpm. Keep in mind Auto's dyno less and this car doesnt have a FAST intake. Its really a great cam. The XFI lobes mimic bigger duration by increasing lift at intake valve positions closer to the seat. It doesnt have really big lift either. A FAST would also sustain a higher forced peak HP rpm closer to 6300. The stock LS2 peaks near 5800 or so due to runner length. For this reason average HP climbs with the FAST (another reason its a great mod for drag racers).
As you can see the low end TQ doesnt suffer from poor low end as some may think a single pattern cam would be. It doesnt have that funky 'big cam dip' between 3000 and 4000 rpms, maintaining its 390rwtq From 3200 to well past 6k on a 'lil ol 6 liter. Coupled with his 3.15 gears, he should see great acceleration light to light taxing any street tire. With a MT ET street tire, it could be a 10 sec threat. I'll guess 0-60 is 3 seconds with the MT's.
Its actually a great blower cam with -6 degrees overlap which makes it near stock driving with barely a lope and zero issues at cruise.
A6 cars bumping compression with a stock converter should run 11.5:1 compression but with a 115+0 grind. If you use a 3200 stall the 230/230XFI 114 (or 115+2 for 0 degrees) is a better cam and still 2 degrees overlap....still a good blower cam.
This package is a prime candidate for E85 which would add about 15hp/20tq to the wheels and not tax the fuel system. All it needs is bigger injectors.
Hope this one finds a home in a daily driver and makes someone smile.
To Listen to the SPINMONSTER
Old Feb 5, 2010 | 09:10 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Old Feb 5, 2010 | 05:05 PM
sweetc6's Avatar
sweetc6
I also have Spins set up 2005 c6 z51
Color
black
Mods
373 gears,vigilante3200 converter,snake charmer,magnaflow exhaust,160stat,AR Headers17/8 with hf cats,comp cam 228/232 114+2 xer lobes,7.425 harden pushrods,patriot gold extreme dual springs,c5r iwis timing chain,UD pully,ported fast and fw mod(spinmonster)ngk plugs,tuned,2008 carbon fibre console.
I really love this set up and car drives amazing. Thanks Spin
cranky's Avatar
cranky
believe me, it makes me SMILE A LOT !!!!!
