Driver window not working
Old Feb 6, 2010 | 09:40 AM
Joe-Tiff's Avatar
Joe-Tiff
1st Gear
Default Driver window not working
A friend of ours was cutting the speaker wire in the driver door to disable the sub and something arced. Obviously something shorted out because now my driver window nor driver side lock is working. Checked the fuses...all good. Now, this part doesnt make sense to me, when I try to move the window, I hear the motor (or relay) in the door click, but it doesnt move. So, that tells me I have power, but why is it not engaging? Also, when I hit the lock button, I get the same clicking noise in the door.
Old Feb 6, 2010 | 10:00 AM
johnodrake's Avatar
johnodrake
Moderator
You may have damaged the memory module. Are your seats working? This accident is a prime example of why you should disconnect the battery whenever you do any electrical work.
Old Feb 6, 2010 | 11:39 AM
fperra's Avatar
fperra
I had the same problem. See this post:
http://forums.corvetteforum.com/audi...ors-on-c6.html
To Driver window not working
