Common C6 Issues
Old Feb 10, 2010 | 08:16 PM
corvettedoug's Avatar
corvettedoug
Default Common C6 Issues
I did a search and did not see a common list of C6 issues. I came from a C5 and I am now in a C6. I know with the C5, there were several items that would go wrong and were easy to fix since others had already had the problem. What are the common issues for the C6?
For instance the C5 had the common issues below.
- Hazard Switch causing turn signals not to work sometimes
- Alignment of headlight stopper that caused it not to close 100%
- Oil Pressure Gauge pegging due to oil seeping into wire connector
- Fuel gauge sticking and needed a fuel cleaner to correct
- ABS/Traction control issue that required a rebuild of EBCM (Lot cheaper than buying new)
- Radio/Console LED backlights needing to be resodered to stay bright
- Starter solonoid causing intermitting starting issues
Old Feb 10, 2010 | 08:47 PM
PCMusicGuy's Avatar
PCMusicGuy
I'll throw a couple in:
-creaking/popping noises from removable roof
-intermittently working hatch pull down motor
Edit~ These are the only things I know of for which GM has no real solution. The new latches do no work for 100% of the cases. They offered to replace the whole hatch motor assembly but I declined. If/when it stops working all together I will remove the assembly and go all manual ala Z06 to save some weight.
Old Feb 11, 2010 | 02:53 AM
HC Mechanic's Avatar
HC Mechanic
What's the fix on the hatch pull down motor?
This is my DD
Old Feb 11, 2010 | 03:08 AM
StoplightWarrior's Avatar
StoplightWarrior
on my c6, 14k miles now, 2 years of ownership:
top creaked, was replaced under warranty
all end links failed, replaced under warranty
door squeaks and rattles, no help from chevy
stock brakes squeak, no help from chevy
so, other than some rattles and annoying noises, nothing too serious, that wasn't addressed by warranty work.
Old Feb 11, 2010 | 05:49 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
I can't believe you left the column lock problem off of your C5 list.
Old Feb 11, 2010 | 07:44 AM
KarlK's Avatar
KarlK
From: Beats UD regularly playing 3D chess, and at life
1. Crank sensor-failed 600 miles from Vette Museum Pick up, drove across America in 200 mile increments. Pull over and restart. No dealer had the part at the time.-Warranty
2. Flying roof-replaced-repainted-TSB-Warranty
3. Power Steering-TSB-Warranty
4. Service Active Handling, etc - 2 weeks in shop-communication errors bewteen puters-replaced BCM, door switch, ignition switch-Warranty
5. Auto shifter stuck-broken reverse lock out pin-Warranty
7. Lean code - Bad valve spring-argued with GM and got a 100K warranty on drive train-Warranty
8. Replaced catalytic converters - When lean code tripped-heated and melted cats-Warranty
9. Replaced 2 sets end links-Warranty-junked GM installed Pfadt
10. Clutch pack grinding-GM replaced-came back-Warranty-replaced with Amsoil sever duty
11. Loose axle nuts
I'll go through some receipts, I'm sure there's more.
Old Feb 11, 2010 | 08:24 AM
nwc6's Avatar
nwc6
[quote=corvettedoug;1573057430]I did a search and did not see a common list of C6 issues. I came from a C5 and I am now in a C6. I know with the C5, there were several items that would go wrong and were easy to fix since others had already had the problem. What are the common issues for the C6?
Perma-Grin every time you plant your right foot..Causes wrinkles
My 08 has only been troubled with minor stuff..
  • Diff chatter-Dealer fixed with oil change
  • MN6 1-2 nibble shift when cold..I changed the tranny oil to Redline D4ATF, and put 8K miles on the car..No longer an issue..
  • Early 08 had FOB not detected..Mine never did it but was in the vin range for recall so I had it done..
  • Roof creaked once, after I had it off for and extended run in the mountains..I loosened the front latches, pushed up on it a bit and re-latched it..No more noise...
Old Feb 11, 2010 | 10:03 PM
dads toy's Avatar
dads toy
dead battery when c6 sits
Old Feb 11, 2010 | 10:08 PM
DaytonaFIC6's Avatar
DaytonaFIC6
yes good point. when your C6 sits for a while the battery will die. If you have an 05 it will say service column lock. Do not tow to the dealer, just charge it up and everything should be fine. Until the battery dies again
Old Feb 11, 2010 | 11:28 PM
Alimony Bob's Avatar
Alimony Bob
2nd Gear
RPO QX3 chrome wheels. Very difficult to clean. I had this option on a 2004 C5 and you could literally wipel the dust off the wheels and they looked great. On the 2008 C6 they are very difficult to clean. When I ordered the C6 besides the crystal red paint being put on constraint and delaying manufacture the QX3 wheels were on constraint numerous times. Other then that the 2008 is the best Vet I've had. Six speed convertible with the F55 magnetic selective ride control this is the only one (out of 14!) that hasn't leaked. It's a great car except the wheels just s**k. I'm working with Chevy now to do something about it. More later.
Old Feb 12, 2010 | 02:15 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Then you need to go to C6 Gen, top of page, FAZ sticky, go down and see Recall Bulletins, and section on Known Issues/ problems. I believe you will find just about everything mentioned above, and more.
Old Feb 13, 2010 | 12:18 AM
corvettedoug
Thanks for the help. I will check out the FAQ sticky
To Common C6 Issues
