where is shift lock control solenoid located?
#41
I'm having this problem on my 07 right now. Using accessory mode didn't help in my case at all. I tried charging the battery, disconnecting the battery, banging on the lever, accessory mode, "key on, eng off" mode, but nothing worked. Car sat overnight at work (not great part of town!) and this morning it worked normally.
I'm not sure how accessory mode would help unless it's a brake circuit issue. If the solenoid isn't activating (burned out, stuck, etc), completing the circuit via another route (accessory mode) wouldn't do anything. Or am I missing something?
Sarah (Assisting Kelly)
Chevrolet Customer Care
#42
For the last year I've had an intermittent problem with the speedometer gauge and HUD dropping to zero. Since they can't duplicate the problem they charge me for their time. I'm sure when my warranty runs out it will fail permanently so I can pay again.
In the mean time, I bought a new battery. It was 6 years old and I've been getting "No FOB detected" intermittently even though my FOB battery is brand new. I tried inserting the FOB into the glove box slot and it doesn't help. So who knows, maybe a new battery might solve all my intermittent electrical issues even though the car has always been on a battery tender and always started the car fine.
#43
Thanks for the offer but I'm not sure what you could do. The dealer said they couldn't do anything if it was currently working properly. It's just as well because they charge me whenever they can't duplicate a problem even though I have a GM extended warranty.
Keep Sarah and I posted on how the new battery treats you. I have noticed on a lot of the treads that when intermittent electrical problems arise a new battery is needed. I am not a technician and cannot diagnose anything, just an observation. You can also send us your VIN and we can look for open service announcements. Let us know,
Kelly J.
#44
Hey C5,
Kelly J.
Kelly J.
#46
Gents, this is old but I need y’all’s advice
Most people quote that the dealer says the entire shifter assy has to i be changed to get rid of the intermittent non functioning of the interlocking solenoid problem.
i have found just the solenoid to buy see pic below. Do you think I can just change the solenoid and solve this annoying problem? GM no longer stock the shifter assy.
