Changing Trans FLuid Help Please
Old Feb 14, 2010 | 08:58 PM
Richor's Avatar
Richor
CF Lifetime Member
Default Changing Trans FLuid Help Please
About to change the tranny fluid. I found a few write ups for changing the rear diff but nothing for the transmission. Can some1 point me to a write-up?
Old Feb 14, 2010 | 09:53 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Your profile says 2006 z51, is it an a6 or m6?
Old Feb 14, 2010 | 11:22 PM
Richor's Avatar
Richor
CF Lifetime Member
sorry its an 06 Z51 Manual
I just got under the car and it looked pretty straight forward, open fill cap, open drain cap and then drain, replace drain cap, refill . replace fill cap... and done . Anything special I am missing?
Old Feb 15, 2010 | 12:37 AM
Richor's Avatar
Richor
CF Lifetime Member
Any1? Car is on jackstands as we speak
Do I just fill until it starts to drip out?>
Old Feb 15, 2010 | 12:52 AM
Silverspeed's Avatar
Silverspeed
St. Jude Donor '13, '15
Here you go.
http://forums.corvetteforum.com/c6-z...-specific.html
Old Feb 15, 2010 | 02:06 AM
Richor's Avatar
Richor
CF Lifetime Member
wooo thanks. Im just about done but good to know I did it right.
Old Feb 15, 2010 | 03:52 PM
Bludog's Avatar
Bludog
Make sure that you are using some kind of pipe sealant around the threads of the drain and fill plugs.
To Changing Trans FLuid Help Please
