LS7 A Good Blower Cam?
Old Feb 15, 2010 | 02:46 PM
06LS2vette's Avatar
06LS2vette
Default LS7 A Good Blower Cam?
just as the title says... I am looking for a cam for a LS2 corvette and I thought this camshaft would be good for a LS2 corvette for a someday magnacharged car with 10psi. Probably a later mod. But for now the car is gonna be stock block. New valve train due to the cam and heads, american racing headers, corsa cat back.
Specs for LS7 cam:
Gmperformanceparts#:12571251
LS7
I: 211 E: 230
(1.8 rocker) I: .591 E: .591
121
Stock LS7 camshaft
Old Feb 15, 2010 | 04:19 PM
DSteck's Avatar
DSteck
Run a 1.7 rocker on the intake side and a 1.8 on the exhaust side, and it makes for a pretty good forced induction cam with good drivability. There are better choices out there, but you can make it work.
Old Feb 15, 2010 | 04:47 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Get a ZR-1 cam. It is intended to be a blower cam
Old Feb 15, 2010 | 07:09 PM
Bushong572's Avatar
Bushong572
That is what Lingenfelter is selling for a blower cam..........and you can buy one for~$150.
Old Feb 15, 2010 | 11:59 PM
06LS2vette's Avatar
06LS2vette
good thinking! Shoot I never though of that! Thanks for the idea!
Old Feb 16, 2010 | 01:59 AM
Randy@RaginRacin's Avatar
Randy@RaginRacin
Supporting Vendor
We use a 221/230 114lsa as a nice blower cam on LS2's. Very light lope and stock drivability.
Shawn
Old Feb 16, 2010 | 09:20 AM
PowerLabs's Avatar
PowerLabs
Yup, I got mine from there
Old Feb 18, 2010 | 01:48 AM
OliverM5's Avatar
OliverM5
Active Streak: 90 Days
I have one for sale (LS7 CAM) $150
oliverm5@aol.com
Old Feb 18, 2010 | 09:28 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
im still not convinced that the zr1 cam is the ideal choice, yes its a blower cam, but based around a positive displacement blower. but hopefully it will make big numbers.
Old Feb 18, 2010 | 09:17 PM
Streetfast's Avatar
Streetfast
It gave me some good numbers.
Old Feb 19, 2010 | 09:24 AM
carlrx7's Avatar
carlrx7
cool. any one have a before and after?
Old Feb 19, 2010 | 10:31 AM
PowerLabs's Avatar
PowerLabs
It is the perfect cam for me: it is a factory cam so driveability won't be "like stock"; it WILL be stock, which is very important on a daily driver like mine... It is also reasonably agressive. Here are the actual, measured specs of the one that went into my car:
Duration at 0.050”: 210 / 242, Lift: .562” int, .557exh, 122LSA.
I've heard nothing but good things about it. When I called up Lingenfelter one of their Engineers told me that they had their own design for a blower cam which went on all their FI cars; when the ZR-1 came out and they had one in their shop they pulled its cam and indexed it; he said they found that the ZR-1's camshaft was virtually identical in every way to the blower cam they had been making since the C5 days! They stopped making that cam and now use the ZR1 cam on all their builds. ECS also reports great results with it.
Sure, it won't make as much power as an all out, agressive blower cam... But power is easy on these cars; I want something that goes beyond just being fast; its got to be fast and 100% streetable
Old Feb 19, 2010 | 09:59 PM
Streetfast's Avatar
Streetfast
Sam, your going to love this cam. There might be some cam that makes more peak power but power under the curve is going to be hard to beat. I make 750 rwtq at 3900 rpms and it is like stock. Good luck on your build, can't wait to here the results.
I believe the number are 210/230
Old May 19, 2010 | 10:18 PM
blackbird345's Avatar
blackbird345
Where can I get the ZR1 cam for $150?
Old Jan 19, 2011 | 01:45 PM
406vette85's Avatar
406vette85
7th Gear
Has anyone tried a ls7 cam in a stock ls2 vette w/headers and stock converter.will this cam hurt low end torque verry much?
Old Jan 19, 2011 | 04:05 PM
JoesC5's Avatar
JoesC5
It's a drop in using the remainder of your valve train.
Old Jan 19, 2011 | 04:08 PM
JoesC5's Avatar
JoesC5
I believe the OP said he was wanting a cam for a Maggie which I think is a positive displacement supercharger.
Old Jan 19, 2011 | 04:52 PM
SDPC's Avatar
0SDPC
Former Vendor
We've got it for $134.44
To LS7 A Good Blower Cam?
