Road racing tires
Old Feb 19, 2010 | 06:00 PM
FRANKENSTEIN4x42000's Avatar
FRANKENSTEIN4x42000
Default Road racing tires
what is the stickest tire i can run on my Z06? what are you guys using? different wheels? any advice would be appreciated. thanks.
Old Feb 20, 2010 | 08:23 AM
corvette pilot's Avatar
0corvette pilot
Former Vendor
are you using these for the track or for the street?
If its just for street use, probably Michelin Pilot Sport Cups. I ran them track and street for a while and they lasted fairly long, and had real good grip when warmed up.
If its track only, then Hoosiers. I don't know if BF Goodrich makes their R1 tires in Z06 sizes, as I now track my 370Z, but thats what I run now and they are 95% the hoosier tire at 80% the cost.
All on stock rims (replicas in my case).
Old Feb 20, 2010 | 08:48 AM
Blurr's Avatar
Blurr
Using stock set up GY Run Flats for street. Separate wheels and tires for track days. Wheels, CCW C10 18x11 front and 18x13 rears. Currently running Michelin Cups 295/30 front and 345/30 rears. Will move to Hoosier R6's when these are worn out. Be VERY careful when the sport cups are cold, they are slippery
Your stickest tire will be a racing slick, but you're now moving beyond just track days, so you'll need to start looking at brake upgrades, brake cooling etc ..........expensive.
Old Feb 20, 2010 | 09:19 AM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
I run 18in CCW Classic all the way around. I also run 18" tires all the way around. I've run Michelin Pilot Sport Cups, Kuhmo V710's, and Hoosier R6's. All very good tires for road course, but the Hoosier are the best imho.that I've run so far. Rear sizes are 315/30/18 Fronts 295/30/18, or as close to those sizes as I can get. Hoosier A6's are stickeir, but they don't last very long if you're roadracing with them.. Try the autocrossing/road racing section for more choices/answers.
Old Feb 22, 2010 | 11:41 AM
FRANKENSTEIN4x42000
Thanks a lot guys that's the info i was looking for.
Old Feb 24, 2010 | 08:05 PM
TTRotary's Avatar
TTRotary
For street use, you should also consider the Toyo R-888. Just an awesome tire: tough, decent wear, incredible grip, and apparently immune to repeated heat cycling and do not need to be heat-cycled at purchase. They drive better than the MPSCs at a fraction of the price.
If for track only, Hoosier all the way.
Old Feb 25, 2010 | 10:18 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Most Corvette racers use 18" wheels all around...Hoosier's are probably the most popular racing tire. I use Kumho 710's with good results.
Old Feb 26, 2010 | 12:20 PM
jmudreamvette's Avatar
jmudreamvette
Toyo R888's for me, Great tire for the track, drag strip and the street, rain tread also is O.K. in the rain.
To Road racing tires
