looking for pics of where you guys mounted you line lock activation swith on c6 z06.
i hooked mine up to a remote relay. so to activate mine i use a key fob to activate and deactivate it. that way when i am done, i can throw it in my glove compartment.
one guy did the remote relay, and hooked it up to the home link
not yet...still waiting on a nice day here in texas when the track is open...they just started opening up for the new season and everyday so far they have been open we have had rain or snow...starting to **** me off
thats how it is here the track opened early and its snowed or rain ever since, im really interested in seeing how much you can gain in the 1/4. think you will see 9s?
i hope so..everyone says i will..not holding my breathe...but once you get faster than a 10.5x the more hp it takes and the harder it gets to drop the same amount compared to a 14, 13, 12, or 11 second car.
true but i havnt seen that with the c6, i think the areo has a lot to do with it. as all the weight to hp calculators seem to be wrong, what shot are you going to use, if you can use the 100, and use it in 2 3 and 4 you should break into the 9s
i'll be on a 150 progressive...i have to figure out how i want to progress it...how much to start out at and how quick to ramp it...i'll post pics in a bit of my setup in the nitrous section...feel sorry for the OP here...lol
if it was me, i would get rid of the progresive, i havnt built a kit for the vette because i always had a limp mod problem and didnt want to take a chance and blow the motor, but on every car i ever used it on the progresive produced a slower time, also it would spin the wheels because the inital hit was to soft and the car wasnt in a hard transfer, i found once the car was in full transfer, then a hard hit it plants harder and no spin, but if the nose drops just a hair it will ligjht them up
i can work the progressive...i can shoot a full 100 or 150 if i want without any progression or ramp...so it gives me the best of both worlds...i just have to work with it and find the best combo
nope i thought the same thing, i had a big race, i put the progressive on to dial it in for the road condition, it spun i set it all the way to 5 10 15 20 % then every couple seconds to come in, it spun, so then i tried setting it to 100% instantly i could tell there was a delay, i actually then ran a button to spray, it still had a wide open throttle switch and fuel pressure switch and ran thru the progressive controller, it didnt spin, but was sluggish and not instantanious, so i cut the progressive out wired direct to a toggle as it would be full on as slong as the gas was to the floor and if i had to lift it would go off, but i didnt have to push a button, so i could put it to the floor the car would be in a full transfer then hit the toggle and it would plant harder while in full transfer, dead hook, this worked on the launch of 200 or 400, if i launched with 400 i could still turn the 200 back on in second, if i launched with 200, i could flip switch too 400 turning the 200 offf, then if need i could push a button for the 200 dry to come back on while the 400 was on making 600 try it at 0 seconds and 100%, then try it bypassing the progresive, also the progressive really wears your noids out, you better get nx or nos noids
interesting...i'll give what i have a shot and may have to swap it out if it doesn't work
