454 LS7 Engine Setup For Wet Sump Available!
Old Mar 4, 2010 | 12:47 PM
Jason 98 TA's Avatar
Jason 98 TA
Premium Supporting Vendor
Default 454 LS7 Engine Setup For Wet Sump Available!
Guys we have a 454 LS7 fresh off the engine dyno & available for anyone looking for a stroker LS7! The engine uses TSP camshaft, PRC LS7 CNC Ported Heads, Ported & Painted FAST Intake, Callies Crank & Rods, Wiseco pistons, and RED Sleeved LS7 Block.
PM or call if you need a custom quote built for this engine. We can build you a custom quote depending on the extra parts you might need to complete it. (IE pan, tray, intake, valve covers, rockers, etc..)
This engine is priced aggressively to move! Don't wait this thing wont last long!
THIS ENGINE USES A STANDARD OILING CRANKSHAFT. IT CAN ONLY BE INSTALLED IN A STANDARD LS2/3 VETTE. WE'D HAVE TO BUILD A NEW ONE FOR A Z06 DRY SUMP APPLICATION!!
Old Mar 7, 2010 | 05:19 AM
C5 Hardtop's Avatar
C5 Hardtop
Thats a lot of naturally asperated power!! shwing.
Old Mar 7, 2010 | 07:30 AM
EDinPA's Avatar
EDinPA
Old Mar 7, 2010 | 11:28 AM
jmudreamvette's Avatar
jmudreamvette
Nice TRQ curve! over 500 @ 3000RPM! and over 700HP NA
Old Mar 7, 2010 | 04:21 PM
snide's Avatar
snide
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07 thru '11
Very
Would it fit in my LS2 powered GTO?
Old Mar 8, 2010 | 01:51 AM
YLOFEVR's Avatar
YLOFEVR
St. Jude Donor '09-'10-'11
Default Big inch small blocks
NICE!!!
I've been waiting to see some big inch sleeves in the LS3 and LS7 blocks like 440 and 454 ci variety. I was impressed with the head work you guys performed on the 418 ci LS3 as depicted in the January 2010 issue of Vette magazine--"Low Buck Brawler".
I am interested in a project which would involve sleeving an LS9 block for 4.125" bore and incorporating an aftermarket Forged 4" Stroke rotating assembly set-up for 9:1 Compression ratio for Forced Induction. I would prefer NOT to use a dry sump system unless it is deemed necessary. What do you think the possibilities of putting something like that together would be? I'd be interested in knowing your thoughts.
Old Mar 8, 2010 | 02:26 AM
craftfox's Avatar
craftfox
I did a build like this, ,440 ci, and was wondering a few things.
We pinned the main caps in our build, and used a step cut into the sleeve, at the top and the bottom, and corrisponding steps in the block, to help with sleeve movement, did you guys do this?
the other thing i was wondering is, i see you guys used ls7 castings, what were the flow numbers on those heads? I decided to run tfs 235, and a fast 92, which i will be upgrading to a 102 with a NW 102, mine made about 30 less hp than this one. what is the comp ratio?
Old May 4, 2010 | 12:09 PM
Jason 98 TA
This engine is using a PRC LS7 cnc ported head that moves right at 400cfm. The engine was under 11.4 compression. The block was done by R.E.D.
Old May 4, 2010 | 12:10 PM
Jason 98 TA
Engine is sold guys!!
Old May 5, 2010 | 12:27 AM
Whistler's Avatar
Whistler
Very nice torque curve! Which of your cams is that?
Old May 5, 2010 | 11:09 AM
Jon@Texas-Speed's Avatar
0Jon@Texas-Speed
Former Vendor
Originally Posted by snide
Very
Yes it will!!!
To 454 LS7 Engine Setup For Wet Sump Available!
