Hey All, I have a C6 and I have been experiencing a squeaky belt from the weather being wet then dry then wet then dry and so on. The belt is the original belt and has 45000 miles on it. I researched and found that the GoodYear Gatorback belt is the best to put on the car. I called the dealership and they want $95 in labor to put the belt on. I thought I would take it to them just incase something happened, they would be liable for it. I just cant bring myself to pay $95 for someone to put a belt on for me.
Please assure me that this process is as easy as it seems. My roommate has built cars from the ground up and is willing to help me.
Thoughts???
Let your friend help. You will find it's easy. The most important thing is to make sure you have a drawing of the routing of the belt. That will save you some time.
Thanks everyone, the belt was installed flawlessly even without having to get under the car. The Gator Back belt seems to be working great. Thanks for all of the responses.
Make sure your crank pulley isn't wobbling .... that is one of the primary cause of belt noise.
