Ethanol Fuel
So if I can't find ethanol free fuel....then what?
Ethanol gives you less MPG and has less HP because it doesnt have the same BTU content as gasoline. Less BTUs means you have to use more fuel to make the same power.
Ive checked Ehtonal content at a few gas stations and they are always at 10-12%. They always will, ethanol is cheaper than gas. The more ethanol they add the more money they make.....
Ethanol, corn alcohol, moonshine...whatever you want to call it, has an octane rating of 116. When you go fill up your tank with 93 octane with 10% ethanol, what you are really getting is 89 octane fuel that has had an octane booster added (ethanol @ 116 octane) which lowers your MPG by about 2 1/2.
In other words, you are paying 10 to 13 cents more per gallon for 90% of a lower grade of fuel (89 octane) that has been cut with an inexpensive octane booster that makes your car get about 2 1/2 MPG lower fuel mileage.
On the other hand, E85 has an octane rating of about 105. Get your car tuned for it and it will be a beast, but your fuel mileage will be cut by nearly 35%. Sacrifices
Once an engine is purpose built for 105 octane, it will gain all the economy back plus another 30+hp from 2 points compression and spark advance.
The reasons for ethanol are to save our planet, have a cleaner engine, and decrease dependency of foreign oil....even if it cost the same.
e85, yes.
-Carl
I don't know that it is cheaper overall. I think it raises the prices of everything else we buy because feed for livestock goes up as it becomes less available. The costs just get passed back to us...
Most of us dont run 12:1+ compression anyways to need the higher octane.
It is all about politics and which lobby gets favored by the government dole.
I seem to recall hearing that there is federal legislation that kicks in this year or next making it mandatory in all states and all gas in all 50 states.
E10 does not give lower MPG. It burns cleaner.
The very reason we arent paying 5 bucks a gallon like every other country is due to E10 and the threat of increasing its percentage if prices get out of hand.
Charlie at RPM has tuned many cars with torco and Meth injection that are running the stock H/C and gained over 20rwhp from it. One such car belongs to forum member JBSblown. His stock H/C car with bolt-ons made such gains and it isnt 12:1 compression.
I have done this conversion and have run octane boost, straightE85, or meth injection on stock H/C cars and see gains typical of tyhis all the time. You may want to revise your posts if you havent done factual tests yourself to disprove what youre spreading around.
Here is a magazine test on a corvette with the tune done at LG motorsports to show the gains on a near stock car:
http://www.vetteweb.com/tech/vemp_08...t_results.html
Personally I think meth injection is the best option because it cools the intake charge lowering IAT's resulting in more power than the other two. It also is only used when the car is under load requiring little to no effort in running so you dont have to hunt for E85 vendors or run into fuel sytem capacity issues. Its cheap at 400-500 for a system, takes little time to install and is 116+ octane.
Here is a post on its use which includes other N/A users who factually gained 25rwhp on the dyno when they retuned with it.
http://forums.corvetteforum.com/c6-t...lications.html
So in summary, YOUR CAR will gain from octane boost, meth injection, or E85 use. At nearly 11:1 compression with an early closing intake valve, the tune it can run on 93 cant be optimum for power due to octane deficiency. As far as the cost, it gets tiring listen to people make statements like 'it gets passed back to us'. If thats true sir they are passed back to you even if you use straight gasoline because the sum net costs are here in the country even if you choose not to use it. Its made and sold to someone and you not buying it doesnt make it 'not made'. As a 105 octane fuel you cant compare it to 93 whcih is exactly the same cost. Cars will eventually run it just as unleaded fuel was forced on us. One day all cars will run it. It runs better, has better throttle response, and burns cleaner.
I welcome it.
