Help would like to lower
Old Mar 13, 2010 | 07:04 AM
Paulkr's Avatar
Paulkr
Default Help would like to lower
I have seen posts on the forums on lowering the C-6 how is this done?
Old Mar 13, 2010 | 12:03 PM
7795TAs's Avatar
7795TAs
Here ya go.
http://www.vetteweb.com/tech/vemp_07...ing/index.html
Old Mar 13, 2010 | 12:24 PM
timd38's Avatar
timd38
Originally Posted by 7795TAs
That pretty much tells the whole story!
Old Mar 13, 2010 | 04:26 PM
Truth's Avatar
Truth
I pretty much followed the vetteweb directions. But I read somewhere you could do the rears with a reciprocating saw if your careful. Thats what I did. Worked like a breeze. better than disassembling the rear suspension and all that. take your time. Jack the rear up at the preferred jacking point. so you can get under it. Then place a floor jack stand under the suspension arm and lower the car just enough to take some tension off the adjusting bolt. Cut away, carefully! God Bless.
Old Mar 14, 2010 | 08:47 PM
Paulkr's Avatar
Paulkr
Thanks for the information
To Help would like to lower
