LS3 heads on my LS2
Old Mar 13, 2010 | 09:48 PM
California Don's Avatar
California Don
Drivin' The Dream
Default LS3 heads on my LS2
Can I just slap LS3 heads on my LS2 engine and cruise down the block? Do they need milling or anything? What other things do I need to do to them? This sounds like an inexpensive way to increase hp on the engine, even a little bit. As I understand it, the LS3's breathe better. Cam is next.
Old Mar 13, 2010 | 10:49 PM
haljensen's Avatar
haljensen
If you do the head swap you'll have to swap intake manifolds also. Lots of LS2's w/L92 heads and the LS3 heads are the same design.
Aftermarket heads/intake would be about the same $$ and make more power.
Old Mar 13, 2010 | 11:08 PM
JayplaySS2's Avatar
JayplaySS2
Try a search dude.
You will also need an LS3/L76 intake, LS3 offset rockers and pedestals. Not to mention the LS3 intake has larger injectors so you will have to have a tune right away.
Old Mar 13, 2010 | 11:53 PM
c6 batmobile's Avatar
c6 batmobile
Just get TF 225's and a fast intake with your cam. You wont regret it.
Old Mar 14, 2010 | 01:30 AM
dsp300c's Avatar
dsp300c
very true
Old Mar 14, 2010 | 01:57 AM
HuskerBullet's Avatar
HuskerBullet
My understanding is the LS3 heads are a fantastic design by GM, but to mate them with an LS2 block and intake manifold is not impossible, but you'll probably have to do some measurements so porting the heads and intake will allow them to match up to a "three-some" marriage.
Old Mar 14, 2010 | 03:12 AM
tjwong's Avatar
tjwong
They will bolt right onto a LS2 6.0L engine block without any issues as long as a LS3 or L76 intake manifold is used. The 2009 Pontiac G8 GT is basically that exact combo with a 6.0L block and the LS3 heads but with active fuel management (displacement on demand) PCM management.
Old Mar 14, 2010 | 09:26 AM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Do you know what the 2009 pontiac is rated at in Hp/TQ. I dont think the L92 Combo will outproduce the Trick Flows in combination with the FAST 92/102. I see in the other thread A LS3 got to 500 RWHP. I know of at least two LS2's that got to 525rwhp with nasty torque curves. A 6.2 L
block with TF Heads & fast will get to ??. I would guess 550. Doesn't that sound like LS7 numbers !
Old Mar 14, 2010 | 11:00 AM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
2009 pontiac is rated at in Hp/TQ. - 361hp 385tq
TFS 225s/FAST 102 w/ported 90mm TB FTW!
Old Mar 14, 2010 | 12:19 PM
Scottie06C6's Avatar
Scottie06C6
I am actually doing this exact same set up, and was curious what all I was going to need to make this transition from my LS2 heads to LS3 heads on my 06 C6. I was told I will need a LS3 intake with fuel rails, and LS3 intake rocker arms? Will I need anything else to make this set-up work? I already have the LS3 heads, Just need to know what else Im going to need? You alls input is greatly appreciated
Scottie
Old Mar 14, 2010 | 12:21 PM
NormWild's Avatar
NormWild
If you could just swap over the L92 heads it would be worth it, but having to buy the manifold is a deal breaker. You are better off with a quality set of aftermarkets such as TFs.
Old Mar 14, 2010 | 01:13 PM
haljensen's Avatar
haljensen
Scottie
Intake rocker arms? Only if you bought bare heads and are trying to use LS2 parts on LS3 heads.
Old Mar 14, 2010 | 02:06 PM
Vito.A's Avatar
Vito.A
What makes the LS3/L92 heads so attractive is Scoogin Dickey has them for $212. They also offer complete packages with aftermarket springs. Yes you also need 8 intake rockers and a new intake manifold, but they are also very inexpensive. A lot of the LS3 guys are buying the new Fast 102, so I see used intakes fairly resonable as well. Also, you can sell your LS2 heads/manifold and recover half the cost.
Old Mar 14, 2010 | 02:26 PM
c6 batmobile
True but performance wise nothing out performs the TF heads coupled with a fast intake for N/A applications.
Old Mar 14, 2010 | 03:16 PM
Echo's Avatar
Echo
One thing you may consider is your cam selection. I know from reading that if you want optimal compression with a cam the possibility of having to fly cut your pistons exists. That isn't cheap.
Old Mar 14, 2010 | 06:13 PM
California Don
Drivin' The Dream
Ok, so I'm changing my heads, etc and now want to cam up. What should I buy? I'm not going to race my car (well, not at a drag strip), but I do want it to perform well without having to constantly fiddle with the engine. Simple swap, good performance.
Old Mar 15, 2010 | 09:57 AM
All_Motor_C5LS6
custom cam from Thunder Racing
To LS3 heads on my LS2
Old Mar 15, 2010 | 10:39 AM
SDPC's Avatar
0SDPC
Former Vendor
Which heads did you decide on? That will dictate what direction you need to go with the cam.
Old Mar 15, 2010 | 10:46 AM
California Don
Drivin' The Dream
I'm leaning toward the stock LS3 heads. I find that when I start going after-market one thing leads to another and my sweet running engine turns into a crazy racing engine. I want to bump up the horsepower but be able to jump into the car and drive it to the store.
Old Mar 15, 2010 | 12:42 PM
NormWild's Avatar
NormWild
Not sure what that statement means, and not sure how a quality set of aftermarket heads will turn your LS2 into a "crazy racing enging". They are designed specifically for your your block, which the LS3s are not, and many using the standard LS6 castings.
