Oil Filter
Old Mar 22, 2010 | 02:49 PM
Whisky's Avatar
Whisky
Default Oil Filter
I know this is simple but is any oil filter better than another for a C6?
Thanks!
Old Mar 22, 2010 | 03:13 PM
MJDVET111's Avatar
MJDVET111
Thanks!
Maybe someone has done some tests whereby they had multiple C6 engines in a test cell and ran them with diff filters for 100k miles and then compared engine wear
Barring that...I am quite sure if you put the AC Delco filter with clean Mobil1 when the DIC says so...you'll be fine and never notice a difference
Old Mar 22, 2010 | 04:03 PM
bob guzzy's Avatar
bob guzzy
I started using Pure One oil filters quite a few years ago and noticed the oil stays cleaner longer, and since the Pure Gold filters became available I use them on all my cars.
Anything is better than Fram...
Old Mar 22, 2010 | 05:53 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
There aren’t many filters better for a Vette then a good ol' AC Delco
And Gene sells um for cheap.
Old Mar 22, 2010 | 05:54 PM
Motorhead-47's Avatar
Motorhead-47
I've started using the new AC Delco UPF48R..same part # used in the ZR1. I figured if it was good enough for the new ZR1 is would be OK in my lowly LS3...and my Tahoe. Less than $10.00 each. I don't know if the guts are any different than the PF48 but the outer shell is quite a bit thicker.
Old Mar 22, 2010 | 06:31 PM
GOLD72's Avatar
GOLD72
Old Mar 22, 2010 | 07:12 PM
///DarkSide\\\
The 48R filters down to a smaller micron, but I’ve read that an LS3's oil pressure goes up some. Is that bad? Not sure...
Old Mar 22, 2010 | 07:59 PM
Motorhead-47
GM says the internals are the same as the PF48... "The Ultraguard Gold UPF48R filter is black in color, has a thicker exterior shell and can be identified as GM part number 12626224. The internal components are the same in both the UPF48R and the PF48 oil filters. The UPF48R can be used in applications where the PF48 is specified."
Old Mar 22, 2010 | 08:13 PM
Whisky's Avatar
Whisky
Thanks for the opinions guys. I didn't know if it was anything special and I'm too lazy to dig out the owners manual and find out!
Old Mar 22, 2010 | 08:18 PM
LS1LT1's Avatar
LS1LT1
This is the oil filter that I use:
http://www.amsoil.com/storefront/eao.aspx
Old Mar 22, 2010 | 08:32 PM
///DarkSide\\\
Per Gene's thread: http://forums.corvetteforum.com/c6-t...rts-house.html
GM Ultra Guard UPF48R Oil Filters
12626224 – UPF48R Ultra Guard Oil Filter - $9.85
These filters come in a case of 12. You can purchase just 1 filter if you’d like.
This is the AC Delco Gold Series oil filter that provides more filtering, etc.
Currently used on the 2009 - 2010 Z06 and ZR1 engines. Can be used in place of PF48.
Old Mar 22, 2010 | 08:44 PM
Motorhead-47
My source was a GM Techlink Article....
http://www.sandyblogs.com/techlink/2008/07/
Old Mar 22, 2010 | 09:33 PM
VET4LES's Avatar
VET4LES
Most filters are ok but stay away from Fram. There have been test that do not rate them too good.
Old Mar 23, 2010 | 12:15 PM
NORTY's Avatar
NORTY
I use PF48's. I get 12 of 'em for $50. Beat that!
Old Mar 23, 2010 | 12:52 PM
NYC6's Avatar
NYC6
Independant studies have shown Fram to be near the bottom of the list.
Good brands from what I remember were the stock AC Delco and Mobil 1 filter. There was another that was rated very high but forgot which one it was.
Old Mar 23, 2010 | 02:06 PM
Ounce's Avatar
Ounce
I appreciate Whisky's question because of what Motorhead quoted from GM, shown above.
My questions are: if the internal components are the same in both filters, doesn't that mean the filtering media, too? And what does a 'thicker exterior shell' do?
Thanks for your time.
oz
Old Mar 23, 2010 | 02:29 PM
HuskerBullet's Avatar
HuskerBullet
Here's what I use....but they now have Eao50. I guess it's an improvement.
To Oil Filter
Old Mar 23, 2010 | 05:57 PM
Motorhead-47
oz
This is another quote from the same tech article. I'm assuming the thicker shell is for the LS9 increased oil pressure.
"OIL PUMP
The dry sump system uses a dual gerotor oil pump, one rotor for scavenge and one rotor for supply . The pump used on the LS9 produces greater volume and higher system oil pressure to provide adequate oil delivery under all conditions."
Old Mar 23, 2010 | 06:54 PM
Bandit1's Avatar
Bandit1
Originally Posted by GOLD72
I use the UPF-44 on my 06.
Old Mar 23, 2010 | 08:46 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Thanks!
Filters are similar to tires in that they are a balance of tradeoffs. The main three capabilites are flow, filtration and capacity. In general, improved filtration comes at the cost of flow with capacity (and quality) being somewhat outliers.
The relatively new AMSOIL Ea Oil Filter uses a technology developed by Donaldson to achieve a very good balance of flow vs. filtration. FYI, AMSOIL also carries the well respected Wix Filters (as Wix partnered with Donaldson and AMSOIL to make the AMSOIL filters).
Applicable part numbers:
05-06:
AMSOIL EAO32
Wix 51042
07-10:
AMSOIL EAO50
Wix 57060
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
