A-6 transmission
Old Mar 31, 2010 | 07:33 AM
reelmccoy76's Avatar
reelmccoy76
Default A-6 transmission
While sitting at traffic light. I hear a clunk from transmission, check engine light comes on. Tran then is stuck in 2nd gear. I must stop car and restart in order to get it to shift back automatically.Everything is back to normal..Except check engine light remains on.HAS ANYONE ENCOUNTERED THIS PROBLEM? Or know what this could be, its happened twice now.
Old Mar 31, 2010 | 09:24 AM
kmthor00's Avatar
kmthor00
I've had 2 A-6's, an 2006 & current 2007, never had issues. Are you still under warranty? Take to dealer
Old Mar 31, 2010 | 12:40 PM
LS1LT1's Avatar
LS1LT1
But now that it seems to be fine (other than the dash light) I would consider disconnecting the battery for a few hours (or overnight even), it likely won't do anything but it also may turn that light off and this issue might not ever come back again.
Old Mar 31, 2010 | 12:54 PM
jxhunte's Avatar
jxhunte
I would check for codes. If you have a check engine light, codes should be pesent. Using a code reader/HP Tuners/etc. connected to the OBDII port, check to see what codes are present. Most auto parts stores will check for codes at no charge. If you are not in possession of a code reader, check with Checker Auto/PeP Boys/Auto Zone/NAPA or other auto parts store for their help.
Old Apr 1, 2010 | 05:47 AM
reelmccoy76
Light went off ,everything back to normal.?
Old Apr 1, 2010 | 07:00 PM
Atomic-Vette's Avatar
Atomic-Vette
Mine does this when it gets hot....
Have fun reading.
http://forums.corvetteforum.com/c6-t...g-problem.html
http://forums.corvetteforum.com/c6-t...gear-gone.html
Old Apr 1, 2010 | 07:09 PM
Tree1985's Avatar
Tree1985
Happened to me... Look at this thread. Basically, they cleared the codes and it worked fine...
http://forums.corvetteforum.com/c6-c...nsmission.html
To A-6 transmission
