Clutch "chatter"....
Old Mar 31, 2010 | 06:19 PM
hal262626's Avatar
hal262626
Default Clutch "chatter"....
I just bought an 08 Pace Car from a forum member yesterday. Car only had 1250 miles on it and it is a garage queen owned by a 57 year old who really pampered the car. I drove it home yesterday (800 miles) and it ran fine. I am 60 and have owned a total of 3 C5's for 12 years of ownership (2 of 'em were MN6 trans)...never had any clutch troubles,no hard launches,etc. I noticed during the trip that no matter how carefully I let out the clutch while starting out in first I get a very slight amount of chatter if the car is at very,very low RPM inching along in traffic.
Old Mar 31, 2010 | 07:59 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
First thing, are you sure it isn't the engine? Have you had it checked for codes? The reason I bring this up, a bad plug wire, or dirty injector could be causing the shatter type vibration. If you are sure it is the clutch, you may want to take off a few times in 2nd or even 3rd gear. This will allow the disc and flywheel to bed-in. If the vehicle has sat for a while in storage, rust spots can form on the flywheel surface where the disc contacts. A few launches in 2nd or 3rd can be enough to correct it. Congratulations on the new to you vette!
Old Mar 31, 2010 | 09:07 PM
Boomer111's Avatar
Boomer111
Learned something new here.
Make sure it is not the clutch packs in the Differential. This chatter is common.
Old Mar 31, 2010 | 09:22 PM
tarik916's Avatar
tarik916
My C6 (z51 package) has the same issue. It was fairly noticeable at 12k miles, but has before increasingly apparent as I approach 20K miles. I use second gear when I want to start slowly and avoid chatter, or I just give it more gas and start in first. I can't tell you why a car with 1,250 miles would do the same, but you are definitely not alone.
Old Mar 31, 2010 | 10:20 PM
Hoonose's Avatar
Hoonose
Even at low miles check your clutch fluid. When it ages or darkens this chatttering is one of the signs. My engagement gets much smoother after a switch out. Look for Rangers details in the FIY section.
Old Mar 31, 2010 | 10:39 PM
hawkgfr's Avatar
hawkgfr
My car did it for about the first 1500 miles....it got better as I drove it and finally stopped completely. I now have almost 24k and zero problems...I also do the RANGER method of clutch fluid cleaning every 2500 miles though as precaution. Even the fluid stays cleaner longer now than it did in the beginning.
Old Mar 31, 2010 | 10:58 PM
Sparo2's Avatar
Sparo2
I have a 05 Z51 and mines never did that with the stock clutch. I does it a little now that I have the RAM clutch in there. Chatter is normal for performance clutches but can be avoided by the way you take off. If I baby it off the line like I was afraid of the car then it will do it...but if I take off with a little more throttle, LIKE A REAL MAN, it doesn't do it. LOL
Congrats on your Vette. Learning to avoid that chatter will become 2nd nature before you know it.
Old Apr 1, 2010 | 12:21 AM
hal262626's Avatar
hal262626
Thanks guys. I will turkey baster the fluid a few times tomorrow. Will report back.
Old Apr 1, 2010 | 12:43 AM
bosco 08's Avatar
bosco 08
Take your car out on a deserted road and run it hard from a standing start and though the first four gears a few times. The chatter should be gone.
Old Apr 1, 2010 | 03:22 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
its an 08, should be under warranty still, at least check. sounds like the rear end is going bad, or needs some TLC
-Carl
Old Apr 1, 2010 | 01:05 PM
hal262626's Avatar
hal262626
I changed out the fluid four times and took a 10 mile drive and the chatter is much better.
Old Apr 1, 2010 | 01:19 PM
Boomer111's Avatar
Boomer111
Not sure but I hope for the best. I do the Ranger monthly maintenance procedure. The clutch fluid is always clean now. 6,000 yearly miles. So every 500 miles I am freshening the fluid so to speak.
Old Apr 6, 2010 | 01:36 PM
marc8090's Avatar
marc8090
My 08 took about 1000 miles for the clutch to break in and the chatter to go away. If the original 1200 miles were mostly on the highway, as well as your 800, then the clutch is still basically brand new. Give it 1000 miles of city driving with alot of normal shifting before you conclude you have a problem.
Old Apr 8, 2010 | 12:46 AM
tarik916's Avatar
tarik916
I replaced my fluid using the "Ranger method" (long process) and the chatter is 95% better. My fluid was DARK and it took about 12 flushes to clear it up. Thanks Ranger!
To Clutch "chatter"....
