Adjusting Hood - Help
Old Apr 2, 2010 | 08:57 PM
rlee's Avatar
rlee
Default Adjusting Hood - Help
Does anyone know if there are instructions on the forum for adjusting a hood for a C6? The front is too high.
Any help-Thanks
Old Apr 2, 2010 | 09:50 PM
timd38's Avatar
timd38
I just installed a hood on Wednesday. The height is adjustable by moving the 4 bolts at the front that are slotted.
Old Apr 2, 2010 | 11:15 PM
Zoxxo's Avatar
Zoxxo
Yep. It's just a repetitive, trial-and-error procedure until you get it just right. Just fiddle with it until you nail it down.
Important: Be aware that you will likely get things way out of wack at first and if you close hood with it way off you can damage the paint on the fenders and along the edge of the hood. It's a good idea to put some painter's tape or masking tape along the edges to protect things in case you forget yourself. It only takes one time...
Always close the hood *slowly* when testing your adjustments - make sure it's not going to dick your paint.
Z//
Old Apr 3, 2010 | 08:09 AM
timd38's Avatar
timd38
Z//
I used a two rolls of tape on mine. Also make sure the rear rubber adjusters are set correctly.
To Adjusting Hood - Help
