Help with gear ratio.
Old Apr 3, 2010 | 09:18 AM
Justasheet's Avatar
Justasheet
Default Help with gear ratio.
I have an 05 automatic with an A4. It is the Z51 so it has the 3.15 rear now.
It has a Cow tune which helped it immensely. I have LT headers and an X-pipe as well.
I may track it soon but this is 99.9% of the time a daily driver.
Should I go with a 3.90, 3.73 or 3.42?
I have done some research and looked at the C5 forums for help as well as they have my tranny.
What say you all???
Jeff
Old Apr 3, 2010 | 01:08 PM
filmjay's Avatar
filmjay
St. Jude Donor '10
Thought that was a 2.73 rear.....
Old Apr 3, 2010 | 03:08 PM
Justasheet's Avatar
Justasheet
Standard is 2.73.
Z51 is 3.15
Old Apr 4, 2010 | 11:28 AM
drivinfast's Avatar
drivinfast
my experience with manual 06 Z51 with 3.42 going to 4.10. on the street lots more shifting in bumper to bumper driving. the handy tool for manuals though it Z51-3.90 and stock-4.10
on the road track(no autox) since I am just starting it didnt make much difference. i concentrated on the "line" more than anything and i kept it in 4th pretty much.
so IMO if you are 99.9% street, why do it?
if you are 99.9% performance then its a great mod.
Old Apr 5, 2010 | 12:40 AM
cranky's Avatar
cranky
save your money on the rear gear. get a yank torque converter. you won't believe the difference. best of all, your street driving will still give you great gas milage still. you will need to add a trans cooler, but that is no problem.
Old Apr 5, 2010 | 08:00 AM
Justasheet's Avatar
Justasheet
I went to the Yank site and they have a 3000, 3200,3400 that sounded great. The first 2 were used with the stock gears (3.15) like you said. I left them an email about it.
The Z51 automatic's have a trans. cooler unless I'm mistaken.
Thanks,
Jeff
Old Apr 5, 2010 | 09:32 AM
Justasheet's Avatar
Justasheet
I guess the track is beginning to call to me!
Old Apr 5, 2010 | 12:18 PM
LS1LT1's Avatar
LS1LT1
Yank, Precision Industries (aka: Vigilante), FTI, all good higher stall torque converters.
Yes they do, but I also believe that all automatic C6s have that same transmission cooler (located within the radiator) meaning that it's no larger or any more special on the Z51 cars than it is on the base or F55 automatics even though it's sort of listed that way when looking at the specs for the Z51 package.
Either way, an aftermarket/auxiliary cooler is still recommended when installing a higher stall torque converter, especially if doing any kind of racing and/or spirited driving on very hot days.
But if you're still set on doing gears (and yes, they do help whether you install an aftermarket converter or not) I would recommend the 3.73s in your case, they make for an awesome combination of street and track performance machine.
3.42s work also but in my opinion just aren't enough of a jump up from the 3.15s to justify the cost...3.90s are great for performance and are still streetworthy but some find them to be more noisey and much less fuel efficient on longer highway trips.
Old Apr 5, 2010 | 12:47 PM
Le Mans Z06's Avatar
Le Mans Z06
Piggy backing on this thread to clarify, does the 2006 Z51 A6 have 3.15 gears too?
Old Apr 5, 2010 | 01:42 PM
Justasheet's Avatar
Justasheet
I believe they're 2.56. Anyone?
Old Apr 5, 2010 | 06:16 PM
LS1LT1's Avatar
LS1LT1
All 2006 and 2007 automatic Corvettes came from the factory with 2.56 gears and there was no other ratio optional/available.
Old Apr 5, 2010 | 06:42 PM
Justasheet's Avatar
Justasheet
Thanks for your great response. i went with the Yank 3200 and some 3.73 gears. I hope to have a report back to you guys in a weak.
Jeff
Old Apr 5, 2010 | 06:43 PM
Justasheet's Avatar
Justasheet
You got me interested in the Yank as I hadn't thought of that yet. I decided on the gears and the Yank but thanks for your help.
Jeff
Old Apr 5, 2010 | 06:47 PM
LS1LT1's Avatar
LS1LT1
That will be a nice combo and you will save a little bit on labor by doing both at the same time versus separately...though you might want to consider some sticky rear tires now as well as you're going to need them.
Old Apr 5, 2010 | 06:50 PM
Justasheet's Avatar
Justasheet
So I'm being told. Any suggestions on tires?
Labor was less although I still got charged for the install of the Yank. I was told that the tranny had to be partially disassembled for it. The good thing is that they're changing the tranny fluid while they're there too.
To Help with gear ratio.
