I would stay with the stock heat range and use your favorite plug type as long as it isn't champion you will be OK.
Plugs loose there ability to fire the fuel over time, I have changed them for people who say they notice a difference in power and fuel economy.
When I raced is super stock we ran champs for the 1/4 mile and changed them every run, they were a great 1 time plug but didn't last for everyday driving. IMHO
Factory heat range will be fine. We run a lot of the NGK TR-55 on stock bottom-end cars without power adders. You can get the iridium plugs if you would like. Either one will be fine for what you are doing and a lot cheaper than something like a Delco plug.
Jon
Thanks guys... I guess I'll stay with the stock heat range...you think there is any difference between NGK and AC Delco ?
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
. . . and Gene has the best price on AC-Delco Iridium spark plugs, and they also are best at preventing the "Service Charging System" message on your DIC.
I would certainly think that unless you go forced induction that you should stick with what you have.
Thanks Gene....Not to worry I'm not going to be Fi in this lifetime.. however I may see a cam, & heads... but when I need OEM spark plugs ..you take a guess as to who I will contact.!!!!
JP... Julio recommended tr55 to me, have been running them ever since, they are cheap, and i change them every couple thousand miles
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Possible stupid question but would you set the gap different if you have a H/C car as opposed to a bolt-on?
I "think" a Head & cam IS a bolt on... however the gap can vary depending on how much compression, cam timing, spark advance, and type of driving you plan on doing....
Same with the heat range...if racing you want a colder plug, if a lot of DD in traffic go to a Hotter plug...
Some racers even "index" the plugs that is when they tighten them the make sure they know which way the gap is located inside the cylender....
I'm not saying plugs are the MOST IMPORTANT thing in an engine, but having the right plug, & correct gap can make a difference... JMO
So do you think at 63K on the originals it's time? I'm almost afraid to change them now. As long as I can keep running 11.5x I don't need the roll bar.
Originally Posted by LS1LT1
We offer the best deal on the planet for NGK and MSD Supercondcutor wires.
Reason we like them so much, besides the lowest resistance in a helicoil wire they are multi angle and allow you to bend the wire away from the exhaust manifold or header.
The irdium plug will last a lot longer before needing to be checked or changed is the advantage to them. NGK offer a few different irdiums but the AC-Delco's are less money by a few a couple bucks/piece. We offer them as well.
