Final question on CAI
Old Apr 12, 2010 | 04:43 PM
TightCornersRacing's Avatar
TightCornersRacing
Default Final question on CAI
About to choose from the Blackwing, AiRaid or K&N. Dont want to cut the schroud fo the Vararam. I know everyone has many opinions, but which would be the better choice of the above.
Old Apr 12, 2010 | 05:10 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
Considering they are all pretty much the same, get the Airaid
Old Apr 12, 2010 | 05:21 PM
One Bad Vette's Avatar
One Bad Vette
Originally Posted by mprisco
K&N.
Old Apr 12, 2010 | 05:24 PM
VET4LES's Avatar
VET4LES
Old Apr 12, 2010 | 07:22 PM
filmjay's Avatar
filmjay
St. Jude Donor '10
Callaway w/ pre-cut shroud. Not having an open shroud is kind of a waste of the CAI, and defeats the purpose.
Old Apr 12, 2010 | 07:46 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
A question about a CAI was wrong...what your looking for is another intake not a CAI.
There's a few guys that have proped open certain areas of the front end to get fresh air without cutting. Do a search and maybe you will like that option.
You need to feel out your profile. If you have a LS 3....you have a good intake, and will go faster only because your billfold will be lighter.
Larry
Old Apr 12, 2010 | 07:52 PM
TightCornersRacing
I just picked up an 08 LS3 with 10k miles. It has the 430 HP. As I mentioned, I really dont want to do any cutting to the shroud. Just looking to have it breath better, then install corsa exhaust. AiRaid, Blackwing, K&N, who knows at this point.
That carbon fiber K&N sure does look good...
Old Apr 12, 2010 | 07:58 PM
Slwsvt's Avatar
Slwsvt
Look at the Halltech Killer Bee II. I just installed one on my Z and it is a nice product. They even have a little suggestion of opening up the shroud just a touch on each end of it, to let some cool air in.
haljensen's Avatar
haljensen
Larry
Buy a CAI, not just a filter/ snorkel replacement. If there is no provision for fresh air to enter the replacement filter it is NOT a CAI.
If you don't cut the shrould or add fresh air ducts to the filter it's not a CAI. K&N wised up, they don't advertize their filter replacement as a CAI anymore. Must have gotten sued?
Old Apr 12, 2010 | 08:04 PM
Andrew6@TheDoubleAA's Avatar
0Andrew6@TheDoubleAA
Former Vendor
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
I had the Vararam installed today and it makes a HELL - O of difference. I was on the feeder and punched it to get on the interstated and it threw me back. My car has always had a fair amount of power but the CAI makes a huge difference. After taking the filter housing off you realize how limited your air intake is. It is a must to cut the shroud .
Old Apr 12, 2010 | 08:27 PM
hawkgfr's Avatar
hawkgfr
The K&N is cheap made..imo
Old Apr 12, 2010 | 08:29 PM
LS1LT1's Avatar
LS1LT1
Old Apr 12, 2010 | 09:26 PM
seevi's Avatar
seevi
Switched from Halltech to KN (warrenty issue). Made a cold air box. Keeps the eat sink down.
Old Apr 12, 2010 | 10:48 PM
sox3's Avatar
sox3
go with the vararam with the pre cut shroud.
Old Apr 12, 2010 | 11:40 PM
HOXXOH's Avatar
HOXXOH
Unless you just really want something different than OEM, getting anything that doesn't allow your engine to breathe air from someplace other than a hot underhood location is just a waste of $$$.
If you're afraid to cut the shroud, then just prop it open and keep the stock filter. Search "propped shroud" for details.
Old May 10, 2010 | 03:39 PM
TightCornersRacing
I ended up buying the Vararam today. Most of the opinions seem to lean on it. Those of you that have the VR, any concerns about more dust entering the engine compartment with the schroud now being cut?
Old May 10, 2010 | 03:43 PM
diablojota's Avatar
diablojota
You could always opt for the Attack Blue drop in air filter from TKO Performance. Several members have installed it with very favorable response. The stock intake is pretty incredible on the LS3, the only thing that stinks is that bulky air filter that comes stock.
Old May 10, 2010 | 04:52 PM
JayplaySS2's Avatar
JayplaySS2
Flip a coin a few times
Old May 10, 2010 | 05:57 PM
FUNTRUN's Avatar
FUNTRUN
You won't get a lot of dust in the engine compartment with the Vararam. You can make a shroud that covers the whole area. It's really easy to make it yourself. You can buy a piece of plastic and cut it to shape with a box cutter or heavy duty scissors. If you are interested send me a pm and I'll take pictures of mine and email them to you so you can get the general idea. I've seen this done by several tuners or you can do it yourself. I did mine and it turned out well. Like I said anyone can do this mod but if needed your local tuner should be able to fabricate something for you.
To Final question on CAI
