C6Z Front Shim affect on camber?
Old Apr 17, 2010 | 07:48 PM
H1ghlndr's Avatar
H1ghlndr
Default C6Z Front Shim affect on camber?
Does anyone know approximately how much camber each shim is worth on the top control arm? I am removing some for more camber.
Thanks in advance.
Bob
Old Apr 17, 2010 | 08:28 PM
BEZ06's Avatar
BEZ06
Thanks in advance.
Bob
Forum wisdom is "about 1/2 degree", but YMMV!
I don't know what tires you're running, but Hoosier says -3 degrees camber, but -2.5 will work real well. Many tires don't need quite that much.
From the factory, my Z06 had 4 washers under each end of the dogbone up front, and 2 washers under each one in the rear.
Just FYI to others reading the thread, the C6 Z06 has the same "dogbones" holding the upper A-arm to the frame in both the front and the rear - but the regular C6 has a different arrangement in the rear and you have to use the eccentric bolts to adjust rear camber.
I started with a camber up front of about -1.2 degrees, and I took out 3 of the washers and was around -2.4 to -2.5 degrees.
In the rear I started with about -1 degree camber and removed both of the washers that were on there from the factory, and that brought me to about -1.7 to -1.8 degrees in the back.
So....I guess mine were actually about 0.4 degrees or so per washer.
I had to adjust my front toe about 9 flats (1-1/2 turns of the tie rod) up front, and about 4 flats in the rear.
Hope that helps!!
Bob
Old Apr 18, 2010 | 03:04 PM
timd38's Avatar
timd38
Here is what you need. Pfadt makes really nice stuff that works.
http://www.pfadtracing.com/catalog/p...products_id/41
Old Apr 19, 2010 | 06:30 PM
H1ghlndr's Avatar
H1ghlndr
Thanks Guys! I took out 2 and now it's off to the alignment shop for my track alignment.
Thanks again,
Bob
Old Apr 19, 2010 | 07:34 PM
timd38's Avatar
timd38
Let us know how it turns out.
To C6Z Front Shim affect on camber?
