Another Problem. One Step Forward One Step Backward (Telescope wheel)
PS also recheck connections under seat...
Ron
Ron
A few things come to mind....Was the memory module new that you installed??If it was did you try putting the old one back and see if it restores the manual &auto move of the telescopic wheel???
Back to the my last post if I remember correctly it had something to do with the tech 2 and re marrying The memory module to the bcm!!
http://forums.corvetteforum.com/c6-t...tech-link.html
CHECK OUT!!! This may be the link I was thinking of....may or may not apply......
PS.
My problem has been erratic seat movement.
thank you thank you!!
Anyway I did some research and I found the following that applies for c5's,it would make sense as you will see that this has to be performed after seat module replacement.I think this is your fix.This calibration can be performed with the tech2 tool as well.This is what I was talking about in a previous post to you.
Telescoping Steering Column Calibration
Telescoping Soft Stops
After replacement of the seat control module, it is necessary to program the telescoping soft stops. Each soft stop is a programmable end of travel that is set approximately 1.3 cm (0.5 inch) from the mechanical end of travel. The steering column has a soft stop set at each end of the telescoping in/out movement. The system uses soft stops to prevent wear on the system by ensuring that the steering column movement stops before it reaches its mechanical end of travel in any direction. The soft stops are initially programmed at the factory. The stop positions may be reprogrammed, which is necessary any time the seat control module is replaced, as described in the following procedure.
Telescoping Soft Stop Programming Procedure
1] Turn ignition to ON, leaving the engine off.
2] To set the telescoping in soft stop, press the telescoping COLUMN IN switch at least eight times or until the column moves.
3] Press the telescoping COLUMN IN switch and hold the switch until the column travels all the way in, and continue to hold the switch about a second after motion stops at the mechanical end of travel. The soft stop for the column in position is now set. The seat control module automatically goes back to the normal mode of operation.
4] Repeat steps 2 and 3, using the COLUMN OUT switch, to set the column out position soft stop
The clip you are referring to I believe is only on the connector starting with m y 08.Unless your car already had this repair done you will not see the orange clip.The clip is on the harness at the base of the steering column,you have to remove the black panel near the pedals as well as the panel which would be near your knees when driving.Follow the wires entering the steering column heading toward the wheel an thats is the connector you are looking for.
I'm not sure this is your problem being you have never complained here about an active handling problem (steering wheel position sensor)all though the telescopic switch is in this connector as well!!!
http://forums.corvetteforum.com/c6-c...post1573981146
Ive removed the panel near your knees but I cant seem to find the connector. Also not sure which other panel needs to be taken off either.
http://s680.photobucket.com/albums/vv162/NVL_AV8R/
Ron
PS I am bringing my car in tomorrow so I will have an update for you sometime on Friday about the module situation (programming etc.)
First off, you are the man! I really appreciate you going out of your way to post the link with pix. That was a HUGE help.
To this point I've disassembled everything I need to get to the connector and check that its properly secured. I've also checked the other connections and cannot seem to get this wheel telescoping though.
I do know the telescope wheel switch is making a closed circuit though because when I'm entering/exiting the car and the seat is going back/forth I can hit the switch on the column and the seat will stop showing that it has interrupted the circuit. I figured that this is a good sign but just cannot figure out where the hang up is.
Anyone have any more ideas?
