so my shop just installed my fidanza twin disc/fly and took it on a test run, the clutch pedal didnt engadge back up, its stuck to the floor. any clues? we also replaced slave with new oem from gm. thanks any response would help
We need a little more info to be able to help you out bro. Start by answering the following questions...
1. Are you able to shift gears while the car is running?
2. How is the clutch fluid level doing?
3. Did the clutch feel fine when it was driven from the shop?
4. How many miles do you have on the clutch and how many of those were break-in miles?
5. Were you doing some hard accelerations when this happened?
6. Do you have a remote clutch bleeder?
By answering some of these questions we can better diagnose the problem.
i got the same problem on my C6 Z51 today.... the clutch just got stuck on the floor and cannot change gears what so ever. It doesn't engage back up, why? I check the clutch fluid cylinder the rubber part was expanded and torn alittle bit. I think that's the problem... You guys know of the part number for that cylindrical piece? Any help would be very helpful
What most likely happened is the slave failed, the bleeder came loose, or the main pressure line came loose. Don't count on the new gm slave; we have put brand new slaves in and we go to test them and they fail. We had another race car that we put a new slave in and two laps into the race it failed. You are most likely going to see fluid on the bell housing indicating that one of the above events happened. But maybe if your lucky, your just low on fluid
The cylindrical piece is just a bladder that fills up the air space in the top of the reservoir to keep humidity out of the fluid.
yes there are fluids left in the reservoir....I already bought an OEM slave master cylinder to replace the whole thing myself to find out that its a big job hahahah...just great! do you guys know of any site I can find instructions on how to? It's really hard to get into the slave cylinder without taking the car apart from the wheel well and also not enough room to work on....any help would be very helpful...thank u guys
You have to drop the entire drivetrain from Bell Housing back to get to the slave cylinder. Did the shop check the throwout bearing face to clutch finger tolerance?
