Gears
Old Apr 23, 2010 | 06:15 PM
barneygookle382's Avatar
barneygookle382
Default Gears
Anyone know if the 293 gears for the 2010 grand sport A6 will fit my 2008 A6 or did they change carrier/case.. Thanks!!
Old Apr 24, 2010 | 09:38 AM
JoesC5's Avatar
JoesC5
I believe the grand Sport A6 has 2.73 gears, not 2.93. The 2.73 gears have been available since 2006 for the C6 and since 1997 for the C5, so fitting a 2.73 ring gear and pinion gear should be no problem in your 2008. But, first, you should verify what ratio you presently have.
Old Apr 25, 2010 | 02:42 AM
lockman's Avatar
lockman
this is what I just found for the grand sport
Transmissions
six-speed paddle-shift automatic
Application:
std.
opt.
Gear ratios (:1)
First:
2.97
4.03
Second:
2.07
2.36
Third:
1.43
1.53
Fourth:
1.00
1.15
Fifth:
0.71
0.85
Sixth:
0.56
0.67
Reverse:
3.28
3.06
Final drive ratio:
3.42
2.73
the second set of numbers are for the Auto it didn't copy right but it says the auto has the 2.73 gear in it.
To Gears
