Service active handling Recall
Old 04-30-2010, 09:03 AM
Braumeister
Braumeister's Avatar
Default Service active handling Recall
Here it is
http://www-odi.nhtsa.dot.gov/recalls...rue&refurl=rss
Old 04-30-2010, 09:42 AM
GregC6
GregC6's Avatar
sweet, i was lazy to fix it myself now it will be done for free
Old 04-30-2010, 09:47 AM
jackarthur
jackarthur's Avatar
Yes, my car (2005 3LT) has had this problem for a year or so -- and the dealer has the car now. However, the orange comb was already installed (a year ago -- to no avail) and they said that met the recall. They did then diagnose a "yaw rate sensor error" after chasing it with a data logger whiloe driving. They are replacing that sensor today (for $300), so we'll see if the sage ends there. Most people seem to have tried the same deal as I did with the orange comb -- maybe some got rid of the problem with it, but not me. It seems to be a weak recall (but cheap for GM) for such a serious problem.
Old 04-30-2010, 10:34 PM
jackarthur
jackarthur's Avatar
Got car back -- it seems the problem was fixed by acting on Tech II code C0196, replacing the yaw rate sensor. I drove it 75 miles after repair without a failure. Before that I could never go 20 miles without a failure. Go figure, you could have the recall done with the orange comb (as I did) and not find this problem unless the code was set and they checked it -- but symptoms are identical, and scary.
Old 04-30-2010, 11:34 PM
torquetube
torquetube's Avatar
On the surface, this doesn't sound like a proper fix.
A "signal interruption" from the wheel sensor can cause the car to crash. Guess what, signals get interrupted - that's reality - especially as the wiring systems of cars age.
The system needs to be able to tolerate intermittent signals and dying sensors, and fail safe.
Is GM's remedy an attempt to prevent signal interruption (band-aid), or a revision to the actual control system to reliably ignore bogus input (real fix)?
Old 05-01-2010, 10:40 AM
Bill Suttie
Bill Suttie's Avatar
Pay close attention to your cars.
Old 05-02-2010, 04:06 PM
drew05vette
2nd Gear
drew05vette's Avatar
Default Refund?
What if you have already paid to have the repair done????
Old 05-02-2010, 10:38 PM
cclive
cclive's Avatar
Interesting that it is only '05 and '06 cars....I would have thought it would have included later years....
Old 05-03-2010, 11:29 PM
da vette guy
da vette guy's Avatar
When you get the recall message in the mail it should have info on how to get a refund for any repairs paid by you concerning this problem.
Old 05-05-2010, 06:17 PM
drew05vette
2nd Gear
Default refund repairs
I am afraid the dealership is going to say what they fixed was not the recall. I spoke with GM today and they wanted to confirm that the repairs that were done were indeed to fix the recall. I know they were but I fear the dealrship will try to get more $$$ from GM by saying the repairs were not for the recall. It cost me $600 and I want a refund, I told the dealership it would be a recall sooner or later!
Old 01-24-2024, 09:30 AM
C6vettrn
C6vettrn's Avatar
Anyone have this done recently under warranty ?
Old 01-24-2024, 10:31 AM
grinder11
grinder11's Avatar
Received 3,605 Likes on 2,556 Posts
There are probably no C6s out there that would still be under warranty.
TCW (01-26-2024)
Old 01-25-2024, 03:43 PM
4SUMERZ
Race Car Tech
Support Corvetteforum!
4SUMERZ's Avatar
Received 2,341 Likes on 1,672 Posts
It was a TSB that the dealer fixed, not a recall. I had this exact code come up on my 2006 a few months ago, and the GM scanner showed it was the connector at the SWPS.
I checked, the comb had been installed. I took everything apart at the connector, checked the pins, cleaned, put back together, zip tied the connector together, and fixed it.
Old 01-25-2024, 05:11 PM
Dano523
Dano523's Avatar
Received 3,062 Likes on 2,199 Posts
the recall, was for the two years with telescoping steering, where telescoping steering could cause the wiring to rub and cause a problem. So this is the reason for the wire clip for just the two years, and was installed oem on the 07 and later years for the same reason as well.
The steering column sensor, that's a problem of just wearing out like any other sensor from either use or time, or in cases where the rack has to be removed, someone turns the wheel too many turns either way, and breaks the sensor. The glitch to the sensor, is the amount of labor is take to replace one, hence same as say a fuel pump in the tanks as well.
As for time issue thing, think of it like the VSS sensor in the diff, and since it it magnetic, just a mater of time until the magnets do go weak from time alone. The difference with this one, since it on top of the diff, pretty simple to replace, without out having to remove parts to get to it.
To Service active handling Recall
Quick Reply: Service active handling Recall
