05 Transmission Problem?
Old May 18, 2010 | 02:47 AM
LS WON's Avatar
LS WON
They don't know what caused it?
Old May 18, 2010 | 09:02 AM
Nasty C6's Avatar
Nasty C6
If its not electrical,the only thing it could be is the 2-4 servo on the side of the case,easy fix.sounds like no-one want's it easy?
Old May 18, 2010 | 10:13 AM
dennis50nj's Avatar
dennis50nj
their was a TSB out on the 05, mine had it, a mis machined case, it clogs the shift solenoid's, they are to replace the whole solenoid pack as a unit, if it happens again they are to replace the trans
Old May 19, 2010 | 03:53 AM
A m o u d i's Avatar
A m o u d i
Thanks Dennis for your input. How was your trans behave before the TSB fix.
appreciate your feedback.
Old May 19, 2010 | 08:49 AM
dennis50nj's Avatar
dennis50nj
you could feel it searching for gears , going back and fourth from 3rd to 4th, converter loc up in and out, searching from 2-3 all depending on speed, sometimes it would just slip then if i shut the car off it would be fine for a while but would always come back
