New brakes make noise
Old May 12, 2010 | 10:45 AM
Justin1014's Avatar
Justin1014
Navigator
Default New brakes make noise
Hello Everyone,
I just installed new pads and rotors (All Factory Parts)on my c6 couple with the Z-51 upgrade. I am now having issues with the front drivers side. It is making a rubbing/swooching sound as I drive and brake. Anyone know what it could be or any advise? Thank you all for your help, this is driving me crazy
Old May 12, 2010 | 10:50 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Originally Posted by Justin1014
Hello Everyone,
It could be a number of things, but the best thing would be to get the wheels off the ground and look over the system.
Old May 12, 2010 | 10:53 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
sounds like something isn't tight causing the caliper to be offset...you need to pull the wheel and double check everything
Justin1014's Avatar
Justin1014
Navigator
Thank you that is what I am getting ready to do. Hope I can figure it out
Old May 12, 2010 | 04:26 PM
marc8090's Avatar
marc8090
Did you lube the sliders and also between the pads and calipers?
Old May 13, 2010 | 08:15 AM
Justin1014's Avatar
Justin1014
Navigator
Default Fixed
Last night I took off the wheel and checked my work. When I replaced the pads I also replaced the clips. The clips were the problem, one was a little bit out of line I had to bend it a little bit and now it is good to go. Thank you everyone for help.
Old May 13, 2010 | 07:56 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
good to hear!
To New brakes make noise
