Wont Start?
Old May 12, 2010 | 11:00 AM
Dave Galbiati's Avatar
Dave Galbiati
Default Wont Start?
Wonder if someone on here has any suggestions.I have a 2005 6 speed with 50000 miles.It also has the priorty start on the battery.It has sat for about a week.When I went to start it dash lit up and radio came on as normal but no cranking??
Old May 12, 2010 | 12:31 PM
Hoonose's Avatar
Hoonose
Most likely dying battery. How old is it?
Old May 12, 2010 | 01:31 PM
Sparo2's Avatar
Sparo2
Are the volts low? What are they reading at?
If the volts are ok then I'd check the wires going to the starter. They get corroded over time and causes the car not to start. That's what happened to me.
Old May 12, 2010 | 04:03 PM
Dave Galbiati
Fairley new optimal battery with 13volts.I will check wires to the starter .Thanks
Old May 12, 2010 | 04:12 PM
Sparo2's Avatar
Sparo2
Let us know what happens. Remember to take the wires off and clean the contacts. Just cleaning the top of it will not cure the problem.
Old May 12, 2010 | 08:01 PM
Dave Galbiati
Thanks,will take off priority start and clean all connections tonight.I will let you know
Old May 12, 2010 | 09:42 PM
saplumr's Avatar
saplumr
Volts mean very little...it's the cranking amps that start the car.
Old May 12, 2010 | 09:44 PM
saplumr's Avatar
saplumr
Did you check the DIC and make sure it didn't say "No FOB detected"?
Old May 12, 2010 | 10:17 PM
VET4LES's Avatar
VET4LES
I would check or remove the priority start also.
Old May 12, 2010 | 11:32 PM
Dave Galbiati
Even with the battery charger on booster start position the car is not trying to crank.also no codes or anything else irregular on the DIC.All connections are clean.There must be a fuse or relay somewhere before the Battery.Tomorrow I will take off the priority start and call dealer.
Old May 13, 2010 | 12:02 PM
Paratrooper307's Avatar
Paratrooper307
Check the clutch switch, sometimes those go bad. Could also be a column lock issue, but usually those display as a fault. Try also putting the fob in the pocket in the glovebox, in case the battery is weak. A load tester on the battery could also give you some good information. On mine a shorted reverse light switch also caused starting issues. Couldn't hurt to bench test the starter too. Good luck!
Old May 13, 2010 | 02:48 PM
Dave Galbiati
Clutch switch could definately be the problem.Before spending $150 on a tow to the dealer I will buy one and try it
Old May 13, 2010 | 11:18 PM
Dave Galbiati
Well I took off the priority start and left the batt dissconnected for half a hour.Hooked the batt back up and back in business???Dont know if it was the priority start or just the fact of dissconnecting batt and letting everything reset?
Old May 13, 2010 | 11:52 PM
vette6500's Avatar
vette6500
steering column lock just beginning to cause trouble. it'll remain random, happen more in heat, etc.
if your column lock sound is getting slower/lazier, that is a good sign it's dying a slow death. you can do a search for column lock if you are sensing slow/lazy column lock/unlocking sounds.
Old May 14, 2010 | 05:07 AM
Paratrooper307
Might have been loose battery connections. Here's some good info if the column lock starts acting up.
http://forums.corvetteforum.com/c6-c...s-for-you.html
Old May 14, 2010 | 09:47 AM
DrivnXcitment's Avatar
DrivnXcitment
Great info thanks!
To Wont Start?
