NPP vacuum control options....
So here is my question: Do the factory NPP cars use a vacuum canister to allow the muffler valves to stay shut at low RPM/high-load? I know there is an electric vacuum solenoid that is controlled by the ECM, and it opens the valves at a certain RPM. I was told that the factory NPP control system is very expensive to piece together, but I have never seen pictures of the components.
I am looking at the different aftermarket NPP retrofit systems (NPP-in-a-box, Sunset Orange, B&B, etc.) to see what the best way to go is. The more popular systems from the forum vendors seem to just be an electric vacuum valve that is controlled by remote. They offer different options as far as how they are activated (visor, DIC, remote, etc.), but appear very similar to each other in design and function.
The other option that looks promising is the system offered by B&B. It appears to use a vacuum canister in line before the electric valve that controls the flaps. It seems that this would allow you to keep the flaps closed, even at WOT (no vacuum in manifold). At least that seems to be the theory behind what I'm seeing.
I'd like some feedback from those have retrofitted these systems or has experience with the factory control system. Below you can see the B&B system as well as one of the more popular ones sold here on the forum. You can see the vacuum canister I'm referring to.
What is the best way to do this?
Thanks,
Andy
My kit uses a vacuum check valve which is installed at the vacuum line at the intake manifold.
The vacuum is stored in the system while you are at high rpm / high load.
For people with superchargers and turbos I offer he vacuum accululator ball to store additional vacuum so that if they are under boost for extended periods of time that they always have enough vacuum to actuate the butterflies.
For most users the vacuum check valve and vacuum stored stored in the line is plenty to allow the butterflies to stay closed under most operations.
Thanks, that is what I was looking for
So, answer this for me: I am cruising around with the flaps closed, and I decide to run full-throttle through first and second gears. Will the check valve be enough to keep the flaps closed (ie. 0-70mph)? What about for a full 11 second quarter mile run? Or is a vacuum accumulator a good idea?
I guess my idea of a controlled bi-mode system is full control of the flaps at all times. Obviously, keeping them open is no problem. My car has a moderate cam, headers and high-flow cats, so it is loud at full throttle. That is one of the reasons I am going with a bi-mode system. Whatever route I go, I want the flaps to stay closed if that is what is being commanded. I don't want them opening on their own during "spirited" driving
Oh, and do you have any pictures of your setup with the vacuum accumulator? Is it a neat assembly like the B&B kit?
Thanks,
Andy
idle and cruzing, lots of vacuum, = flaps closed = quiet
WOT, no vacuum = flaps open = loud
of course i only hook up the line when im going on LONG trips greater than 3 hours, usually the line is just capped back at the mufflers, so its WILD all the time!!
-Carl
I had a friend who went to pick up his car at the museum and they recommended and sell the mild to wild set up.
Get set and easy to install !!!
In fact, a Talon90 a forum vendor is running a special on it:
http://forums.corvetteforum.com/c6-p...group-buy.html
Thanks!!
RPI DESIGNS, LLC. - C5/C6/C7 Corvette Parts
4000+ C5/C6/C7 Parts & accessories - Forum members get 10% off with SS2007 coupon at checkout
Like us on www.facebook.com/rpidesigns and you might win $100.
Our brand new C7 Corvette Z06 Style Side Skirts come painted in Carbon Flash Metallic, see them here!
email: rpi.designs.customerservice@gmail.com Web: www.rpidesigns.com
