cove screens
Old May 17, 2010 | 03:40 PM
nydave's Avatar
nydave
2nd Gear
Default cove screens
im on my second pair of cove screens and tried everything to get them to stick alchol any one have this prob. if so what did you do
Old May 17, 2010 | 05:55 PM
cranky's Avatar
cranky
hey dave, if you use clear silcone, and let it set up overnight, your problems will be gone. here is a trick i use: roll up some hand towels [2] then get some ty raps [3] for each screen. insert them in the back side of the screens, top,middle, and bottom in a "u" with the long part sticking out thru the front side. insert the screens inside the fender with the ty raps sticking through the cove hole in the fender. then take your hand towels and install inbetween the ty raps. cinch them around the towels to hold the screens in place. tighten loosely at first till you get the screens where you want them. then tighten up snugly. then go inside the fender and apply the clear silicone. let sit overnight. have installed 28 sets of these and not one has come loose. hang in there, cranky
Old May 17, 2010 | 06:40 PM
Swiftrider08's Avatar
Swiftrider08
Spend the money for the GM ones that were actually designed to always stay in place. No glue, no silicone and no letting it sit overnight to dry.
To cove screens
