102 mm throttle body
Old May 22, 2010 | 11:25 AM
the1n_Only's Avatar
the1n_Only
Default 102 mm throttle body
I need on ASAP. Does anyone have them in stock?
Old May 22, 2010 | 11:50 AM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Hinson can get you the 100 MM LINGENFELTER maf. Plug & Play with
the 100 mm card to LS2 adaptor. Looks like you have a pretty aggressive setup going on. When do you expect to be completed ? Sorry I thought you were looking for A MAF.
Still HINSON has the 100 mm Nick williams TB. I dont know how they are working compared to others.
Old May 22, 2010 | 12:31 PM
the1n_Only's Avatar
the1n_Only
I got the car running last night and it sounds wicked. For now im running a stock throttle body on a ported 102mm fast. I just ordered the Halltech killerbee II to match the 102mm FAST, hints why im looking for a throttle body.
My goal is 500+ HP to the wheels and 10.5's N/A and 9.7's on the bottle.
Old May 22, 2010 | 12:51 PM
LSCHLEM's Avatar
LSCHLEM
I have no doubt you will make 500 RWHP+ . I cut my TF's to 59cc to get some compression. I just got under the wire with the small cam.
I can see why you want a 100 mm TB to keep it at 102 all the way thru.
Dont estimate your 92 MM TB. Our #1 is at 526 RWHP backed up by a 10.57 and 9.74 W Nitrous on only one pass. Do you have gears? I hope you keep us posted especially since we have but little Data on how the
FAST 102 W TF's is really working. Who ported your 102 ? Thanks, Leon
Old May 23, 2010 | 03:17 PM
the1n_Only's Avatar
the1n_Only
A clutch and gears will be on my short list when I get everything finished up. Vengance did the port work on the FAST.
To 102 mm throttle body
