heat insulation for headers
Old May 26, 2010 | 01:51 AM
GregC6's Avatar
GregC6
Default heat insulation for headers
I am currently running kooks not coated, so the engine bay gets very warm when I sit in stop and go traffic in 80+ degree weather
header wrap was not recommended, but what about other products that help in reducing the heat in the engine bay? my main concern in the alternator/cable and starter
what are your opinions on these products
Thermo-Tec Header Manifold Blanket
http://www.thermotec.com/products/full/14003/14003.html
HIGH-VELOCITY EXHAUST JACKETS
http://www.thermotec.com/products/full/11240/11240.html
I was also thinking of fabricating a oem type heat shield but that might not be possible for a while, and i do not feel like taking the headers off
any other recommendations?
Old May 26, 2010 | 03:03 AM
Licit's Avatar
Licit
I didn't see what price they have for the exhaust jackets, did you find one? I will definitely get my LT's coated when I get them.
Old May 26, 2010 | 09:53 AM
GregC6's Avatar
GregC6
jegs and summit sell them for $79.XX
i wonder if these are safe to use with the SS headers
Old May 26, 2010 | 01:11 PM
filmjay's Avatar
filmjay
St. Jude Donor '10
Wrap isn't recommended on street headers because it holds moisture and will destroy your expensive headers over (a relatively short) time, causing leaks, warping, cracks, etc...
I can't see this happening with the foil blankets since foil doesn't hold moisture. But the insulation is what you're concerned with. If it's lined with the thermal weave, then you'll have the same issues as wrap. If it's simply a foil overlay blanket, you should be good to go.
Old May 26, 2010 | 01:22 PM
PAKirk's Avatar
PAKirk
Instead of wrapping the headers, why don't you try wrapping the parts you're worried about? You mention cables; should be able to wrap those.
Old May 26, 2010 | 01:54 PM
GregC6's Avatar
GregC6
figured it would be easier to wrap the headers than all the other items
Old May 26, 2010 | 02:51 PM
LeMans05C6's Avatar
LeMans05C6
I think i want to get the LG Super Pros when i make my big purchase and would like to get them JetHot coated, does the coating make a difference?
To heat insulation for headers
