CAI questions.
Old Jun 3, 2010 | 04:59 PM
LS1LT1's Avatar
LS1LT1
Originally Posted by haljensen
Don't get buried in Adspeak. CAI means COLD AIR INTAKE, not a $300 filter. If there is no provision to allow fresh air into the filter it's not a CAI, it's just an expensive fliter replacement. If you don't have to cut the radiator shroud or run ducting to the filter it's NOT a CAI.
Originally Posted by DSteck
I'm also referencing LS7 applications. If you want to split hairs, the fastest bolt-on C6 Z06 did 10.19 with a Halltech, and the fastest NA C6 Z06 did 9.95 with a Halltech intake.
True, but that car also had a Vette-Air unit (which uses many of the same exact 'catching the air at the grill opening' principles as the Vararam) used in conjunction with that Halltech.
Old Jun 3, 2010 | 05:16 PM
dennis50nj's Avatar
dennis50nj
He never specified, DID HE? And I'm not about to e-stalk somebody just to figure out what engine they have. Jesus dude, you know what, you win. You can **** straight up into the air higher than me. Congrats.
well Mr.Watson.... this is the C6 performance section
Old Jun 3, 2010 | 05:34 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
Old Jun 3, 2010 | 05:37 PM
DSteck's Avatar
DSteck
Last I checked, my car was a C6 still.
Old Jun 3, 2010 | 06:06 PM
dennis50nj's Avatar
dennis50nj
very true, but most Z06 owners ask their questions in the Z06 section, but of course you can still read and post in the c6 section, and even show your signature when you want to prove how hi you can **** as far as internet stalking if thats what you call it, you apparently do, a friend sent me this is that you stalking the OP, or just checking facts after you post a stupid statement car avatar DSteck Elless2 jycllc LS1LT1 Neumonic2002 Rocketmanwpb sea six theofel
Old Jun 3, 2010 | 06:48 PM
LS1LT1's Avatar
LS1LT1
as far as internet stalking if thats what you call it, you apparently do, a friend sent me this is that you stalking the OP, or just checking facts after you post a stupid statement Recent Visitors
The last 10 visitor(s) to this page were:
Old Jun 3, 2010 | 08:19 PM
theofel's Avatar
theofel
St. Jude Donor '10-'13
THE TOP 4 SPOTS IN BOLT/ONS IS HELD BY VARARAM, MAYBE MORE, the cam only is vararam, me, tonyb4, c6devil, and heads and cam are all vararam except dpc300 and im positive i will beat that when i add heads or even before with just cam only
Lets not get into a p.zzing contest..Top spot for LS3 bolt-on is not held by the VaraRam CAI. It is held by the BPP Vortex. I still think the quality of the material as well as the fit and finish of the VaraRam is inferior to most of the other CAI's.
Old Jun 3, 2010 | 09:07 PM
JoesC5's Avatar
JoesC5
I decided to go with the Vette-Air to get outside(cold?) air into the air filter compartment and a Attack Blue filter element in the stock air filter housing. From what I've read the stock LS3/LS7 air filter housing is a good design. If you don't want to use an oiled cotton filter then put in a LS9 element into the stock housing. Using that combo, I'm not going with a tune(want to protect my warranty). I may be mistaken, but from what I've read, most of the big HP claims come from the tune(and 160* thermostat) used with most of the CAI installations, not just from the CAI.
Vette-Air + Attack blue = ~12 RWHP gain(according to the mfg's) for $273.19 including shipping & including a clean & re-oil kit. I'm not really looking to gain any horsepower but to try and keep from losing any HP by keeping the computer from pulling timing because of high IAT this summer when it's 95-100 degrees in the shade.
Old Jun 3, 2010 | 09:10 PM
BlueSpeed's Avatar
BlueSpeed
I went with the callaway honker because of the oem look, the ease of accessing the filter to clean and aslo because it sits high, so water ingestion is unlikely unless you completely submerge the nose of the vehicle in a very deep puddle. The LPE is a similar design but may be a bit more difficult to access the filter for cleaning. The BPP filter kit is also a similar concept with a different filter. I believe the Vararam intake scoops sit much lower on the vehicle so water ingestion is a concern which is the reason I didn't choose vararam. There was also an older thread of a cold air intake that copied the callaway design at a fraction of the cost but can't remember the name.
Good topic as there was a huge thunderstorm today in south florida causing large puddles and the honker made it through! Hope this helps.
Old Jun 3, 2010 | 09:18 PM
BowTieBlood's Avatar
BowTieBlood
Have to get under the car to clean the LPE filter; quality and appearance is top notch though, which is why I went this route. If you have some ramps to drive up on, you just need to loosen one clamp to pull the filter out from underneath.
Old Jun 3, 2010 | 09:49 PM
One Bad Vette's Avatar
One Bad Vette
Vararam is junk in my opinion. I would go with a BPP Vortex if looking for a true cold air or maybe a Halltech with a vette air. With that said, im running a K&N "CAI" only because I got it used cheap. Seems to be making horsepower though since last I checked im making the most out of stock headed n/a ls3's.
Old Jun 3, 2010 | 09:51 PM
dennis50nj's Avatar
dennis50nj
whats with all the pissing going on around here, the OP has an LS2 not an LS3, EVEN IF YOU PUT THE VORTEX VARARAM OR ANY OTHER CAI ON THE BIGGER LS3 IT CANT **** AS FAR AS THE LS2
Old Jun 3, 2010 | 11:34 PM
  #33
LS1LT1's Avatar
LS1LT1
True, among the automatics it is at least.
I believe that jbsblownc5, just .02 behind you, was using a Vararam but hey, number one is still number one no matter how ya slice it.
That is key to what I look for in a CAI, if I wasn't so convinced that the Vararam achieved that goal best then I'd likely pursue some iteration/combination involving the Vette-Air.
So some of these other CAIs somehow magically keep water from getting in (like some claim that a Vararam doesn't do) yet they still somehow allow just as much cool air in as the Vararam as well?
Now I know that air weighs less than water and all but it just seems like one of those "ya just can't have it both ways" or "I've chosen to compromise some better 'IAT cooling' air in order to have a tiny bit more insurance against water ingestion" situations or something.
Maybe it's just me but I'd always thought that the path of least resistance netted the best performance results. Maybe not.
Old Jun 4, 2010 | 01:03 AM
  #34
bosco 08's Avatar
bosco 08
Vette-Air, Halltech Killer Bee with the Bee Hive. High quality parts that fit well and work even better.
Cooler air is cooler air no matter how you get it. I would buy them again.
Old Jun 4, 2010 | 02:36 AM
  #35
theofel's Avatar
theofel
Dennis...No one is debating the the fact that your car runs great and you have an LS2. This is not about which block is better. We are all trying to help out a forum member with some of our personal input... so he could make an educated decision on a CAI for his daily driver in South Florida. It's not about how fast your car is. Your car has alot more going for it than just a CAI. Your winning combination would probably not suffer if you changed to another quality CAI. You have a long record of defending the VaraRam and that is your right. But please don't knock all other products that you havent tested. Some of us also like a CAI that looks better in the engine compartment(subjective)and some of us don't care....and thats OK also. I hope someone closes on a positive note!
Old Jun 4, 2010 | 03:30 AM
  #36
dennis50nj's Avatar
dennis50nj
Originally Posted by Alothman_Miami
I think im going to go with vararam
i think he already did close on a positive note
Old Jun 4, 2010 | 07:25 AM
  #37
theofel's Avatar
theofel
i think he already did close on a positive note:d
cute
To CAI questions.
Old Jun 4, 2010 | 07:34 AM
  #38
dennis50nj's Avatar
dennis50nj
cute
all in good fun, all you guys get to uptight,, have you decided what your going to do next, nos H&C charger turbo, the LS7 seems like a good mod
Old Jun 4, 2010 | 08:25 AM
  #39
BlueSpeed's Avatar
BlueSpeed
what I meant is that the vararam scoop sits low on the bumper (see pic below) so you have a higher likelihood of "scooping" water in when going through a puddle. The callaway, lpe and bpp filters do not have a scoop, they sit on the shroud which is much higher off the ground. I have not claimed one is better than the other performance wise but surely there is a difference just in the design when water ingestion is an issue.
Old Jun 4, 2010 | 08:42 AM
  #40
DSteck's Avatar
DSteck
Oh no, after the fact, I clicked his profile to see if it said anything about his car. I wasn't about to search through his post history to get more information. You are completely ate up. According to some others you're a blow hard too.
Whatever, I'm done. There's no sense talking to people who don't listen.
