CAI questions.
Old Jun 5, 2010 | 01:21 PM
  #61
HOXXOH's Avatar
HOXXOH
Originally Posted by JoesC5
I removed the Attack Blue filter element and put the OEM factory filter back in. Took it out on the highway and most of the surging has stopped. I still see some when light to no throttle at 70MPH. Very little but still there. I did not get the Service Active Handling or Service Traction Control with this drive. Still have the CEL. Apparently the Vette-Air is still causing problems with the MAF.
Will disconnecting the battery cancel the CEL? Does anyone know how many start cycles it normally takes to clear the CEL if there are no more problems?
From what I experienced (LS3) and Vararam explained, that there may be surging for the first 50 miles or so, depending on speeds driven. My A6 may have dampened the effects somewhat, but they were still evident initially. Several factors related to incoming air have changed and the computer needs time to make the gradual adjustments.
After ~20K, I put my stock unit back on for a few days while modifying the Vararam. I had surging again for a bit. Then surging a bit when I went back to the modded mod again.
My advice is to give it a little time.
Old Jun 5, 2010 | 01:33 PM
  #62
tomiboy's Avatar
tomiboy
Originally Posted by BlueSpeed
what I meant is that the vararam scoop sits low on the bumper (see pic below) so you have a higher likelihood of "scooping" water in when going through a puddle. The callaway, lpe and bpp filters do not have a scoop, they sit on the shroud which is much higher off the ground. I have not claimed one is better than the other performance wise but surely there is a difference just in the design when water ingestion is an issue.
For drag racing this looks great, but for a HPDE or road racing it looks like you would see hi temps with how much radiator is blocked
Old Jun 5, 2010 | 02:22 PM
  #63
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
Originally Posted by LS1LT1
There's a chance that I'll be going again this year. I went the first year (in Memphis) but missed the last two.
I was at Gateway once before as well, back in 2000 for the Viper Owner's Invitational event that was held in St. Louis that year.
When we closer to the event send me a PM if your coming and we can get a group together for a beer and BS outing!
Looking forward to the shoot out and meeting some CF members
Old Jun 5, 2010 | 02:57 PM
  #64
haljensen's Avatar
haljensen
Won't make any difference, the C6 is a bottom feeder, most of the cooling air comes from under the grill/facia.
Old Jun 5, 2010 | 03:34 PM
  #65
JoesC5's Avatar
JoesC5
The base C6 has an opening below to get air but the Z06 has this opening blocked off. The Z06 gets all it's cooling air through the grille. The radiator opening behind the grille is the same size on both the base C6 and the Z06.
Old Jun 5, 2010 | 03:56 PM
  #66
haljensen's Avatar
haljensen
The Z06 is a front feeder as you stated but at a HPDE the car speed will force more than enough air thru that big opening.
Old Jun 5, 2010 | 04:32 PM
  #67
JoesC5's Avatar
JoesC5
Spent the last two hours making a baffle and installing it. Disconnected the battery while working on it to clear the CEL.
Just got back from a romp on the freeway. The car ran perfect. No surging at all. Let off the gas at 80 MPH and the car SMOOTHLY decelerates, no bucking like before. Drove around town at low speeds, everything perfect. CEL did not come back on.
If AirBusPilot and I ever cross paths I'm buying him the biggest steak he can stuff down his gullet. I made the baffle from some 1/8" Plexiglas I had laying around instead of the old license plate like he used. Made it 3" X 10" and mounted exactly like his pics show.
If Vette-Air happens to read this post, I hope he will either provide a baffle with the Vette-Air or mention that a baffle may be needed and furnish a drawing of the baffle and pics of it installed. Might save some people a bunch of grief on down the line.
I haven't decided what to do with the Attack Air filter. Since I have the car running with the Vette-Air and the factory filter element, I hate to mess with it.
While researching(asking for help) for my problem, I see that Callaway has had a problem with some applications using their Honker with surging, etc. I see where they have a baffle now, appears to be metal with punched louvers, to solve the problem
I wonder if it would be worth the time(and money) to rework a Halltech BeeHive to fit around the stock airbox to separate that cool air that the Vette-Air is letting in, from the underhood heat coming from the engine compartment?
Old Jun 5, 2010 | 04:40 PM
  #68
dennis50nj's Avatar
dennis50nj
Originally Posted by theofel
Maybe October....Would not like to drive from Florida to NJ and back in the snow and ice. Most of my family lives on LI....So this might work out!
we will have to check the almanac to see a weather pattern for oct
check it out for the day a night race will be better
Fri Oct 1 7am NHRA POINTS SERIES QUALIFYING TAD & TAFC/ RECORD RUNS
Sat Oct 2 7am NHRA POINTS SERIES QUALIFYING ELIMINATIONS/ TAD & TAFC
Sun Oct 3 8am NHRA POINTS RACE SERIES FINAL ELIMINATIONS
Tue Oct 5 430pm ~ Street & Grudge/ Fall Points Gamblers Series
THR Oct 7 430pm BIKE NIGHT MOTORCYCLES ONLY
Fri Oct 8 430pm Unmuffled & Muffled Test & Tune Everything Can Run No Time Available
Sat Oct 9 8am Mopars at Atco Car Show/ SwapMeet/ Mopar Bracket Race
Sat Oct 9 8am Nostalgia Stk-SSS/ East Coast Gassers/ Mandra
Sun Oct 10 9am Nostalgia Stock SSS/ East Coast Gassers/ Mandra
Sun Oct 10 9am Test & Tune Everything Can Run No Time Available
Tue Oct 12 430pm ~ Unmuffled & Muffled Test & Tune Everything Can Run No Time Available/ FPS Gamblers
Thur Oct 14 430pm Unmuffled & Muffled Test & Tune Everything Can Run No Time Available
Fri Oct 15 6pm $20.00 A CARLOAD AFTER 6:00PM
Fri Oct 15 6pm Heads Up Index 10.0 & 12.00
Fri Oct 15 11am $$ RACE TECH/ JEGS/ Summer Series Shootout $5,000
Sat Oct 16 9am $$ RACE TECH/ JEGS/ Summer Series Shootout $10,000 ( High Rollers)
Sun Oct 17 9am $$ RACE TECH/ JEGS/ Summer Series Shootout $5,000
Sun Oct 17 9am OUTLAW 10.5 SHOOTOUT ,DRAG RADIAL 275, HEADS UP INDEX 8.50
Sun Oct 17 NO TEST & TUNE
Tue Oct 19 430pm ~ Unmuffled & Muffled Test & Tune Everything Can Run No Time Available/ FPS Gamblers
Thr Oct 21 430pm Unmuffled & Muffled Test & Tune Everything Can Run No Time Available
Fri Oct 22 430pm Unmuffled & Muffled Test & Tune Everything Can Run No Time Available
Sat Oct 23 9am NATIONAL DRAGSTER CHALLENGE Race Junior Dragsters
Sat Oct 23 12pm NATIONAL DRAGSTER CHALLENGE (Wally Race) S.PRO- Pro-Street
Sun Oct 24 9am NATIONAL DRAGSTER CHALLENGE (Wally Race) Motorcycle
Sun Oct 24 9am Test & Tune Everything Can Run No Time Available
Tue Oct 26 430pm ~ Unmuffled & Muffled Test & Tune Everything Can Run No Time Available/ FPS Gamblers
Thur Oct 28 430pm Unmuffled & Muffled Test & Tune Everything Can Run No Time Available
Fri Oct 29 430pm Unmuffled & Muffled Test & Tune Everything Can Run No Time Available
Sat Oct 30 9am TEST & TUNE OPEN TO ALL CARS & Motorcycles
Sat Oct 30 9am NO TIME BIKE NATIONALS
Sun Oct 31 9am NO TIME CAR NATIONALS/ North VS South/ Match Grudge Race
Sun Oct 31 9am No Time Bikes Invitation Only/ No Regular Test & Tune
Old Jun 5, 2010 | 07:46 PM
  #69
kev101's Avatar
kev101
just be carefull on the rain
Old Jun 9, 2010 | 06:32 PM
  #70
Myhardtop's Avatar
0Myhardtop
Former Vendor
Originally Posted by lebvette
Larry, I installed the Vette-Air and the Attack Blue filter on my Z this morning. After looking at the difficultly in removing/replacing the grille I decided to attempt installing from under the car. Having a 4-post lift is required(IMHO) to install the vette air from under the car. As luck would have it, I just happened to have two lifts in my garage . I did it by myself. It wouldn't have taken as long if I had had a helper(with small hands). The blood cleaned up pretty easy.
I haven't changed the filter yet. I Haven't really decided, but it will be a TKO, or a ZR1.
Yeah, come to think....I had a little blood on me also. I wish Carlos was close by, he can install one in his sleep, and I love writing checks to someone that knows what they are doing.
My car didn't throw any kind of code either.
Larry
Thanks Larry.
Yeah, I can install a Vette-Air scoop in less than 15mins. And no blood and no blondies
Here are my secrets:
*warm engine bay...it makes the shroud more flexible and easier to cut.
*I dont need the template...I already know where/how to cut. But if implemeting the template, then tape to shroud and scribe, then cut.
*A box cutter works pretty well when shroud is warm.
*Jack vehicle on one side and remove air baffle (Z06)...3 10mm and 3 7mm bolts.
*Slide Scoop from underneath and install.
*I have my trusty craftman mini wrench holding the bottom nuts while I snug the bolt from the top. The nuts are nylon threaded and it will NOT come loose.
That's it.
Go out and romp on it
Thanks,
Carlos
