Thermostat Gasket Needed?
Old Jun 3, 2010 | 10:18 PM
Whisky's Avatar
Whisky
Default Thermostat Gasket Needed?
Hi all!
I'm in the process of ordering a 160d stat. Jegs says a gasket is not needed but I'm seeing other vendors where the gasket is included.
Do I need a separate gasket or not?
Thanks!
Old Jun 4, 2010 | 01:49 AM
hungryhippo's Avatar
hungryhippo
you should be able to reuse the old one.
Old Jun 4, 2010 | 02:14 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
i used the stock gasket with some permex
Old Jun 4, 2010 | 07:54 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
They are probably thinking about the gasket between the housing and block as older, conventional thermostats require. This type of gasket is not needed on LS series engines.
Old Jun 4, 2010 | 08:04 AM
bluekey28's Avatar
bluekey28
Just replace my stat. in my LS3 with a 160 deg. Stat. comes with an "O" ring style gasket attached around the stat. No other gasket is required. Be aware there is a tab on the "O" ring that lines up with a notch in the stat. housing so that the stat. is positioned properly. There is a bleed hole in the stat. that must be upright. Hope this helps.
Old Jun 4, 2010 | 08:11 AM
Whisky's Avatar
Whisky
Exactly.
Thanks for the info gentlemen!
To Thermostat Gasket Needed?
