St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Originally Posted by Bill Curlee
On to the NO Start issue.
My 06 Coupe ignition switch just failed. Not the same exact failure symptoms but simular. Consider that as something to check. The C6 ignition swich is complex and NOT very hardy. Im surprised they last as long as mine did.
Heres the post that i posted about the failure and repair:
If you have NO DTCs,, then it thinks everything is normal with all the MONITORED systems. In the C5 when this happens, the start circuit is at fault and most of the time, the damn Starter SOLENOID is the issue. Whack the starter lightly ) with a mallet and try to start it.
