Remote clutch Bleeder failed.
Old Jun 12, 2010 | 06:21 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Default Remote clutch Bleeder failed.
Imagine picking your car up at the airport parking lot after a long trip and finding that your clutch has literally sucked itself to the floor.
That was my experience last week. The crimped connection on the end of my remote clutch bleeder line seems to have failed, and it leaked out all the clutch fluid while I was gone. I re-filled the reservoir but now my clutch engages 1/2" off the floor, and never disengages completely. The drive back from LaGuardia was excruciating; I almost called a tow truck.
What a piece of crap. Very frustrated at this. Can someone tell me if it is possible to replace that remote bleeder without removing the bellhousing / dropping the transmission / removing the engine? Any thoughts on what would be the easiest way to replace it?
Old Jun 12, 2010 | 09:12 PM
torquetube's Avatar
torquetube
It is possible to access the bleed port, and to replace the remote bleeder, without dropping anything. I've done it.
You might also consider schlepping the car to a hose shop and having the failed hardware at the end of the hose replaced in situ.
Old Jun 12, 2010 | 11:51 PM
07MontRedcp's Avatar
07MontRedcp
How did you pull that off? I've always heard the only way to do that was when you were doing a clutch change.
BJK
Old Jun 13, 2010 | 12:14 AM
torquetube's Avatar
torquetube
BJK
http://forums.corvetteforum.com/c6-t...post1559740085
Old Jun 13, 2010 | 10:31 AM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
It's your call, but if you try to replace it without removing the slave cylinder you will be working mostly by feel in very tight quarters. If you cross-thread the bleeder while installing it you will have an even bigger problem.
Old Jun 13, 2010 | 12:03 PM
skamp's Avatar
skamp
You left your car at LGA?
Steve
Old Jun 13, 2010 | 12:58 PM
PowerLabs's Avatar
PowerLabs
Steve
Sure did... It's my DD so what else would I use to get to the airport?
I like the idea of taking it to a hose shop... Guess I'll try and find one in NJ...
Old Jun 13, 2010 | 01:15 PM
AirBusPilot's Avatar
AirBusPilot
That had to suck.
I bought a "throw away" car for airport duty. Cheap.
Old Jun 13, 2010 | 02:00 PM
ninjavette's Avatar
ninjavette
http://www.americanhose-hydraulics.com/hose_shop.htm
http://www.hoseshopinc.com/catalog/
Old Jun 13, 2010 | 02:09 PM
timd38's Avatar
timd38
Originally Posted by AirBusPilot
That had to suck.
Ditto. And never park on the top floor..
Could the end just be replaced on the car?
Old Jun 13, 2010 | 03:26 PM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
The same thing happened to my POS clutch line bleeder. It leaked on the crimp as well. The bleader screw is also made of VERY cheap material, and does not seal very easily.
Old Jun 13, 2010 | 04:16 PM
torquetube's Avatar
torquetube
My RPM Motors bleeder has been installed for three years without any trouble. What brand did you have?
Old Jun 14, 2010 | 01:13 AM
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
A more recent version of the same...
Old Jun 14, 2010 | 03:31 AM
SpinMonster's Avatar
SpinMonster
Jeez Sam, Does anything give you a break?
Dinner is on me when we meet up.
Old Jun 14, 2010 | 08:54 AM
PowerLabs's Avatar
PowerLabs
Yeah man, tell me about it! My methanol tank is leaking too. How about that?
I can't wait to get a different car
Awesome You should come to Carlisle btw..
Old Jun 14, 2010 | 11:58 AM
3 Z06ZR1's Avatar
3 Z06ZR1
I'm ready to send to him a care package. Shezz the bad luck!
You will overcome Sam.
Old Jun 14, 2010 | 12:56 PM
tim414's Avatar
tim414
St. Jude Donor '12
Also contact 'Ranger' (his handle on this site). He also posted how to do maint on your Z06 clutch as well (any clutch I guess). The maint he described keeps clutch from sticking too.
To Remote clutch Bleeder failed.
Old Jun 14, 2010 | 01:05 PM
AirBusPilot
After decades (and an untold fortune spent on mods) I finally decided with my latest vette I'd never mod again. I like reading the tech and adventure stories you guys put out though.
Old Jun 14, 2010 | 01:30 PM
techvette's Avatar
techvette
Good Lord! You are having to deal with this on top of the engine issues, AND your meth tank is leaking? I will keep my fingers crossed for you that some good automotive luck comes your way soon!
Old Jun 14, 2010 | 01:38 PM
PowerLabs's Avatar
PowerLabs
No need to contact him: Ranger claims if you use a turkey baster to replace the fluid in your master fluid regularly your clutch won't stick.
Well, in 65,000 miles I replaced the fluid on my clutch exactly once. My clutch never stuck. The premise that I need to use a turkey baster to replace clutch fluid every month on an 80 thousand dollar car is ridiculous to me: the factory states that the fluid fill is good for the life of the clutch, and that is what everyone who is not on this website to be exposed to that idea does. If your clutch is sticking you've got other problems than just dirty hydraulic oil on your lines...
My problem is very simple: an aftermarket part (the remote bleeder) failed. It needs to be replaced. No turkey basters or fresh fluid is going to make that line stop leaking...
