Junk Trick flow head?
Old Jun 14, 2010 | 11:56 PM
c6 batmobile's Avatar
c6 batmobile
Default Junk Trick flow head?
I need some help locating one so I can use it for fly cutting. I emailed Trick Flow and vengeance where I purchased my original heads from but no dice. Ive tried TEA twice but havent gotten a response. There has to be a place where I can get a broken head so I dont have to risk damaging mine to fly cut. Anyone have any tips on a location?
Old Jun 15, 2010 | 02:05 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
maybe SPIN has one?
Old Jun 15, 2010 | 07:26 AM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
If you are running TF Heads you have a ton of room in there. Unless you are contemplating running a monster Cam there is plenty of room for
P/V clearance. What are you trying to do that requires Flycutting ?
Old Jun 15, 2010 | 10:31 AM
c6 batmobile
Running a monster cam . I was planning on upper 230's duration which would put the lift over .600. If there is going to be enough room for that without fly cutting then that would be awesome.
Old Jun 15, 2010 | 11:13 AM
CVS PERFORMANCE's Avatar
CVS PERFORMANCE
I'm running mid 240's intake/mid 250's exhaust with lift around .630. You don't need to flycut.
Old Jun 15, 2010 | 12:10 PM
LSCHLEM's Avatar
LSCHLEM
Wow the setup you are running is very close to mine. What are your numbers now. Its funny Im running the same size cam you are and Im planning on moving up to A 231/ 236 with the lift being 619 with no concerns at all about flycutting. This is the SPINMONSTER Cam.
Old Jun 15, 2010 | 01:01 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
I used to have a set of junk heads that were left over after they blew my motor up
I decided to use them for long range target practice to make myself feel better.
Old Jun 15, 2010 | 07:40 PM
haljensen's Avatar
haljensen
Interesting what a ballistic tip 150 grain 30-06 does to cast aluminum.
Old Jun 16, 2010 | 09:23 AM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
You will more than likely have PLENTY of room. I have run cams ALOT bigger than that without fly cutting.
Old Jun 17, 2010 | 02:41 PM
c6 batmobile
Well thats good to know. My current Rwhp is only about 430 due to my manifold. The fast is in my garage waiting to be put on. My tune also leaves a lot to be desired. Its less than good to say the least about it. I havent decided exactly on the cam Im going with but it will be around the mid to upper 230's on both ends. Ill just use some putty to make sure that I dont have any PTV issues and stick that sucker in there.
To Junk Trick flow head?
