Can you put a C6Z Diff behind a A6?
Old Jun 15, 2010 | 12:30 AM
adam205348's Avatar
adam205348
Default Can you put a C6Z Diff behind a A6?
DTE and RPM both show all their built diffs and then they have specific ones for the A6. Is there something different that will keep you from putting one of the C6Z diffs behind a A6 as it looks both of those company are building those to handle more power.
Old Jun 15, 2010 | 09:10 AM
jmt1669's Avatar
jmt1669
St. Jude Donor '11
Yes it can and has been done. You will need different trans mounts though. Contact member, "thesubfloor" he is the man with the plan!
Old Jun 15, 2010 | 09:13 AM
SL33PER's Avatar
SL33PER
Yes, I have one and with the Pfadt Trans mounts it bolts right up.
Old Jun 15, 2010 | 04:27 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Apart from needing offset differential mounts from Pfadt, it's pretty much a direct bolt-in and will ultimately be your strongest option.
To Can you put a C6Z Diff behind a A6?
