2010 automatic shift from D to S-mode
Old Jun 15, 2010 | 04:48 PM
denny4673's Avatar
denny4673
3rd Gear
Default 2010 automatic shift from D to S-mode
When driving in D and then shifting to S-mode, shouldn't the DIC display the gear at the time of the shift? Do you have to hit the paddles to find out what gear you're in with a possible gear change occurring? Nothing in the manual on this and Two Chevy dealers said that they would research same and get back to me. I'm still waiting.
If in fact the DIC does not display the gear at the time of the shift and you have to hit a paddle, can the system be modified or reprogrammed to display same at the time of shift from D to S-mode without having to hit a paddle?
Old Jun 15, 2010 | 04:58 PM
PCMusicGuy's Avatar
PCMusicGuy
I can't speak to the 2010, but on my 07, it will not display the gear in the DIC until you manually change it while in S mode. After that it will display all the time. If you use your buttons to display something else in the DIC, such as oil temperature, the DIC will again display the shift indicators next time you shift. It is quite annoying sometimes in the way it works but I guess they were trying to please the largest subset of buyers.
Old Jun 15, 2010 | 06:07 PM
kmthor00's Avatar
kmthor00
Same on my 07'
Old Jun 15, 2010 | 06:16 PM
BigMay60's Avatar
BigMay60
The same programming for all of the C6 A6s. You cannot see what gear you are in on the DIC until you hit the manual paddles in the S mode.
Old Jun 15, 2010 | 06:56 PM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
When I put my 08 a6 in s mode the trans shifts on its own just like in d mode until I activate the paddle then the trans stays in the gear I choose and shows what gear I am in.
Old Jun 15, 2010 | 08:32 PM
rovers2000's Avatar
rovers2000
that is correct that the display only shows the gear you are in when you paddle shift it. It would be cool to have is show you all the time is s.
To 2010 automatic shift from D to S-mode
