Someone pushed my ignition switch or button in through the dash. Looks like I will need to go into the dash to disconnect and reinstall it. How do I get into the dash to remove the switch? Will I have to buy a new switch?
I doubt you'll need to buy a new switch. If anything the tabs that hold the switch probably broke.
To gain access to the switch start by removing the lower panel located below the steering column. I believe it's 2 screws and the rest is just a matter of popping it out. Once you have that panel out you can look underneath and see what happened. In case you need another speedometer bezel I have one here. Just PM me.
YEP! The switch just snaps into four small tabs. It will most likely just snap back in.
Mine went bad and I had to replace it. The spedo benzel just snaps into place. Once you unsnap it, you can pop it out and easly see the switch and where it goes.
Try to pop it back in. This happened to me when a heavy-handed friend pushed it in the middle. Just remove the lower dash panel and you can probably push it back into place, doubt its broken.
