I think that any GM accessory installed by a dealer will not void the warranty, so I would think something like the GM cam or the GM performance exhaust (I think it's a Corsa exhaust) would not void the factory warranty.
I'm not 100% sure on the above but it would make sense.
I've had two different dealers do minor warranty work and I questioned the coverage before I told them who I was. I informed them of my mods (Z06 manifolds to tips, Vararam, tune) and they said "no problem".
I think each dealer has their own policy, so it pays to ask first. Be honest and upfront and especially anonymous until reaching a decision.
You would want to talk with your dealer, it will be up to them as to what they will cover above a cat-back exhaust which will gain very little.
The DEALER has no say on whats covered by Warranty, the Warranty is by GM and the GM Rep is the only one to decide if a repair is Warranty or not. The Dealer may try to turn it in as a Warranty repair but if GM says no the Dealer has to eat it.
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Even the GM cam could give you warranty issues. It is intended for off road use on non-emission controlled cars and requires computer prggramming to make it run correctly. That tune alone will void your powertrain coverage.
St. Jude Donor '08
thanks for all the replies, just getting a chance to check it now. Talked to my dealer and a procharger will definitely void the powertrain, they said I can get a cold air intake though and that will keep the powertrain in tact. So much for a 200hp boost.
ac foiltape your airfilter intake bottom for a homemade tech. Alot of hot water pump houses right their.A160 stat will not hurt either.None of this can void waranty. Seen alot of people do it.
