Help! Failed NJ Emissions Inspection multiple times
Old Jun 25, 2010 | 02:00 PM
bfabiano's Avatar
bfabiano
Cruising
Default Help! Failed NJ Emissions Inspection multiple times
I took my 2006 C6 through for the 4th time and failed again. The Evap System, Oxygen sensors, and Oxygen sensors - heated come up "not ready". They said because I had changed the battery and not driven the car enough they may not be reset. I followed the GM drive cycle instructions and put 125 miles on it and it still failed! Has any one run into this issue or have any advise? Would my supercharger and performance tune cause this problem? I would appreciate any help I can get.
Old Jun 25, 2010 | 02:14 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Most certainly yes. Do you run catalytic converters on your car?
Your tune is most likely what is making the car fail: I am guessing you either run no cats or have the codes off anyways despite running cats.
Old Jun 25, 2010 | 02:19 PM
bfabiano's Avatar
bfabiano
Cruising
Yes I have cats on the car. In fact the cat converters come up "ready". If that's the case, I assume the codes maybe off?
Old Jun 25, 2010 | 02:28 PM
tomiboy's Avatar
tomiboy
Do you always flunk emmissions with a tune?
Old Jun 25, 2010 | 02:34 PM
bfabiano's Avatar
bfabiano
Cruising
This is the first time I took it through. I never needed an inspection before the performance mods.
Old Jun 25, 2010 | 03:03 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
BUT, are the cats OEM? If they are aftermarket, fugetaboutit
NO
Old Jun 25, 2010 | 03:16 PM
Larry/car's Avatar
Larry/car
With emissions testing you have to be afraid to do these mods. The possibility is that you might have to return the car to stock. Keep us informed.
Old Jun 25, 2010 | 03:24 PM
LS1LT1's Avatar
LS1LT1
No, not in every case at least.
Old Jun 25, 2010 | 03:27 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
I'm not supposed to tell you this (so please keep it just between us ) but there are DTC codes that can be turned off in your tune which will make all of the readiness tests complete almost instantly.
Old Jun 25, 2010 | 04:19 PM
bfabiano's Avatar
bfabiano
Cruising
Do you know which codes??
Old Jun 25, 2010 | 04:24 PM
thesubfloor
Not off the top of my head but if you send me a PM tomorrow night I can find the tune on my laptop as I went through the same thing with a Trans Am I was having trouble getting smogged for the same reason.
To Help! Failed NJ Emissions Inspection multiple times
